Hi everyone,
I’m still relatively new to Arduinos and programming and am having trouble getting the leds to light up.
I am connecting a HC-05 to the Arduino Nano and a Neopixel LED Strip.
The phone connects fine with the Blynk App.
I started by using the code from the example and tried troubleshooting it with information online.
My ZeRGBA settings:
Merge
V1
Send on release: ON
Here is the code that I’ve used:
#include <Adafruit_NeoPixel.h>
char auth[] = "4ae94b10958f41d19f00419ad9145946";
SoftwareSerial SerialBLE(10, 11); // RX, TX
#define PIN 6
#define NUMPIXELS 1
Adafruit_NeoPixel strip = Adafruit_NeoPixel(NUMPIXELS, 6, NEO_GRB + NEO_KHZ800);
// Input a value 0 to 255 to get a color value.
// The colours are a transition r - g - b - back to r.
uint32_t Wheel(byte WheelPos) {
if (WheelPos < 85) {
return strip.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
} else if (WheelPos < 170) {
WheelPos -= 85;
return strip.Color(255 - WheelPos * 3, 0, WheelPos * 3);
WheelPos -= 170;
return strip.Color(0, WheelPos * 3, 255 - WheelPos * 3);
BLYNK_WRITE(V1)
int R = param[0].asInt();
int G = param[1].asInt();
int B = param[2].asInt();
for (int i = 0; i < NUMPIXELS; i++) {
// pixels.Color takes RGB values, from 0,0,0 up to 255,255,255
strip.setPixelColor(i, strip.Color(R, G, B)); // Moderately bright green color.
strip.show(); // This sends the updated pixel color to the hardware.
SerialBLE.begin(9600);
Blynk.begin(SerialBLE, auth);
strip.begin();
strip.show();
Thank you for your time.
