Arduino nano+bluetooth(hc-05) issue
A saw an issue with library. i tried basic bluetooth example and i saw its working with or without auth token.
I can confirm that.
Yes it is true.
You should enable BLYNK_DIRECT_CONNECT for library to check auth token of the phone.
It looks like it doesn’t work on some hardware, but should work on hc-05
