Hi I am using Arduino Nano hooked up with two sensors and a relay for watering plants. Everything works perfectly on Blynk but around 48 hours on-line the Arduino freezes!
I can´t find any similar treads about this when I do a google search, any ideas?
Best regards Villi
#include <WiFiNINA.h>
#include <BlynkSimpleWiFiNINA.h>
char auth[] = "XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX";
char ssid[] = "XXXXXXXX";
char pass[] = "XXXXXXXX";
const int Relay_pin = 8;
const int Snuningstakki = A0;
int lesa_takki_fasti;
int skrifa_takki_fasti;
const int RakaSensor = A1;
int RakaFasti;
const int dry = 718; // value for dry sensor
const int wet = 316; // value for wet sensor
const int Float_sensor = 7;
int Float_fasti = 0;
const int LED_RED = 2;
const int LED_BLUE = 3;
const int LED_GREEN = 4;
WidgetLCD lcd(V2);
void sendFlagToServer() {
lesa_takki_fasti = analogRead (Snuningstakki);
skrifa_takki_fasti = (255./1023.) * lesa_takki_fasti;
RakaFasti = analogRead(RakaSensor);
int Rakastig = map(RakaFasti, wet, dry, 100, 0);
Float_fasti = digitalRead (Float_sensor);
Blynk.virtualWrite(V4,Rakastig);
Blynk.virtualWrite(V5,Float_fasti);
if (Float_fasti ==0) //HVÍTUR 0 , GRÆNN 1
analogWrite (LED_GREEN,0);
digitalWrite (LED_RED,HIGH);
else {
analogWrite (LED_GREEN,skrifa_takki_fasti);
digitalWrite (LED_RED,LOW);
void sendFlag2ToServer() {
lcd.clear ();
lcd.print(1, 0, "FORÐABÚR:");
lcd.print(1, 1, "Vatn vantar");
else {
lcd.clear ();
lcd.print(1, 0, "HVÍTA KERFIÐ:");
lcd.print(1, 1, "Vatn til staðar ");
//Serial.println ("Rakaskynjari");
//Serial.print (friendlyValue);
BLYNK_WRITE(V1) {
int Relay_Value = param.asInt();
if (Relay_Value !=0)
digitalWrite (Relay_pin,HIGH);
Blynk.virtualWrite(V7,255);
else {
digitalWrite (Relay_pin,LOW);
Blynk.virtualWrite(V7,0);
timer.setInterval(1000L, sendFlagToServer);
timer.setInterval(9950L, sendFlag2ToServer);
pinMode(Relay_pin, OUTPUT);
pinMode(RakaSensor, INPUT);
pinMode (Snuningstakki, INPUT);
pinMode(Float_sensor,INPUT_PULLUP);
pinMode (LED_BLUE,OUTPUT);
pinMode (LED_RED,OUTPUT);
pinMode (LED_GREEN,OUTPUT);
