I’m trying to use an Adruino MKR1000 with Blynk to make for a project that is resilient in case of wifi drop out (or similar).
When I run code similar to below (very cookie cutter, sample only), the MKR1000 will hang up at the virtualWrite() function if I restart the wifi router.
How can I make this more resilient to these kind of problems? Can I set up Blynk to timeout when something bad happens? What about the MKR1000? Can I set up a watchdog that will restart everything when needed?
#include <BlynkSimpleMKR1000.h>
// other setup stuff here..
Blynk.begin(auth,ssid,pass);
float val;
val=getValFromSomewhere();
Blynk.virtualWrite(V1, val);
There is a BLYNK_CONNECTED() and BLYNK_DISCONNECTED() function which you can use to achieve a reset. They are standalone functions, so they go outside of other functions. E.g.
stuffHere();
doStuffWhenDisconnectHere();
I added the following snippet the new function never fired. The Serial.println() never even ran.
Any ideas?
I like the Blynk platform, but the API documentation needs a lot of work. It’s frustrating stabbing in the dark like this.
Serial.println("disconnected!");
if(Blynk.connected()!=true)
Blynk.connect();
Well, if there’s no error during compilation, at least it’s right. You got your serial monitor enabled? Also in the setup()?
Yeah, I’m dumping stuff to the serial monitor fine right until I reset the wifi router, then everything dies.
Passing compilation doesn’t tell us enough unfortunately. I could add any function (with any name) and pass compilation. If Blynk is suppose to call that function on the other hand is a different question.
I’ve added a watchdog timer using this Adafruit library: https://github.com/adafruit/Adafruit_SleepyDog
It seems to work well.
You can’t do virtualWrite within loop. Because of flood.
I’ve only posted striped sample code. My real code throttles virtualWrite() to about once per 4 seconds.
Is the Arduino Blynk library able to cope with wifi dropout in a reliable manner? Is there any sample code available?
Ah ok.
At the moment Blynk automatically tries to reconnect. So in general all you need is Blynk.run in loop + BLYNK_CONNECTED as @Lichtsignaal mentioned. Regarding BLYNK_DISCONNECTED… not sure. I’ll call @vshymanskyy here.
