Arduino Mega with SIM868
I need help with my arduino mega and SIM868. I connect SIM868 to arduino mega serial1.
Want to use GPS stream widget but when I start Blynk app the hardware is not online.
    Follow us:                  http://www.fb.com/blynkapp
                                http://twitter.com/blynk_app
  Attention! Please check out TinyGSM guide:
    http://tiny.cc/tiny-gsm-readme
  WARNING: GSM modem support is for BETA testing.
  Output any data on Map widget!
  App project setup:
    Map widget on V1
#define TINY_GSM_MODEM_SIM800
// Default heartbeat interval for GSM is 60
// If you want override this value, uncomment and set this option:
//#define BLYNK_HEARTBEAT 30
#include <TinyGsmClient.h>
#include <BlynkSimpleSIM800.h>
char auth[] = "JfwLDUsmA7BuxufVD9L8E9GMk4347efes";
// Your GPRS credentials
// Leave empty, if missing user or pass
char apn[]  = "gprswap";
char user[] = "mts";
char pass[] = "064";
// Hardware Serial on Mega, Leonardo, Micro
#define SerialAT Serial1
// or Software Serial on Uno, Nano
//#include <SoftwareSerial.h>
//SoftwareSerial SerialAT(2, 3); // RX, TX
TinyGsm modem(SerialAT);
WidgetMap myMap(V1);
  // Set GSM module baud rate
  SerialAT.begin(115200);
  delay(3000);
  modem.restart();
  // Unlock your SIM card with a PIN
  //modem.simUnlock("1234");
  // If you want to remove all points:
  //myMap.clear();
  int index = 0;
  float lat = 51.5074;
  float lon = 0.1278;
  myMap.location(index, lat, lon, "value");
This is serial output…
19:35:16.743 -> Initializing modem...
19:35:23.601 -> [9791]
19:35:23.601 ->     ___  __          __
19:35:23.601 ->    / _ )/ /_ _____  / /__
19:35:23.601 ->   / _  / / // / _ \/  '_/
19:35:23.648 ->  /____/_/\_, /_//_/_/\_\
19:35:23.695 ->         /___/ v0.6.1 on Arduino Mega
19:35:23.742 ->
19:35:23.742 -> [9884] Modem init...
19:35:24.445 -> [10655] Connecting to network...
19:35:40.707 -> [26734] Network: 22005
19:35:40.707 -> [26735] Connecting to vipmobile ...
19:35:52.982 -> [38899] Connected to GPRS
19:35:52.982 -> [38908] Connecting to blynk-cloud.com:80
19:36:07.034 -> [52819] Connecting to blynk-cloud.com:80
19:36:21.077 -> [66720] Connecting to blynk-cloud.com:80
19:36:35.086 -> [80610] Connecting to blynk-cloud.com:80
19:36:49.090 -> [94503] Connecting to blynk-cloud.com:80
19:37:03.135 -> [108408] Connecting to blynk-cloud.com:80
19:37:17.169 -> [122320] Connecting to blynk-cloud.com:80
19:37:31.189 -> [136209] Connecting to blynk-cloud.com:80
19:37:45.214 -> [150105] Connecting to blynk-cloud.com:80
19:37:59.258 -> [164013] Connecting to blynk-cloud.com:80
19:38:13.289 -> [177914] Connecting to blynk-cloud.com:80
What happens if you change this:
to this:
Blynk.begin(auth, modem, apn, user, pass,"blynk-cloud.com",8080);
I change what u tell me and I have again:
20:30:35.830 -> Initializing modem...
20:30:39.914 -> [7050]
20:30:39.914 ->     ___  __          __
20:30:39.948 ->    / _ )/ /_ _____  / /__
20:30:39.948 ->   / _  / / // / _ \/  '_/
20:30:39.983 ->  /____/_/\_, /_//_/_/\_\
20:30:40.016 ->         /___/ v0.6.1 on Arduino Mega
20:30:40.049 ->
20:30:40.049 -> [7144] Modem init...
20:30:40.967 -> [8082] Connecting to network...
20:30:45.376 -> [12441] Network: 22005
20:30:45.376 -> [12441] Connecting to vipmobile ...
20:30:50.821 -> [17839] Connected to GPRS
20:30:50.821 -> [17850] Connecting to blynk-cloud.com:8080
20:31:04.851 -> [31746] Connecting to blynk-cloud.com:8080
20:31:18.879 -> [45640] Connecting to blynk-cloud.com:8080
20:31:32.904 -> [59542] Connecting to blynk-cloud.com:8080
I even change this line:
to
#define TINY_GSM_MODEM_SIM868
and
#define TINY_GSM_MODEM_SIM808
but can’t go online in app
Do you have a SIM from a different network that you can try?
Thanks, I change the SIM from different network and now I’m online, but I can’t get GPS position from SIM868. How I can get GPS map position? I set Map widget but I have only default position and can’t get real data
