Hi Guys, I was just working on the Software for the Solar Panel Tracker I am building, and I want to use Blynk as a way to see some Data, like brightness and Voltage.
I was planning to use an Arduino Mega 2560 as the “computer” and for a Network connection I bought the ENC28J60 LAN Shield, because there is no Wi-Fi in my basement.
So right now I was trying to test it because the LAN Shield just Arrived and I wired it up, like some guides I found on the web suggested.
When I tried, it always repeated the same thing:
[2127] Getting IP...
[3467] IP:192.168.178.145
[3468]
___ __ __
/ _ )/ /_ _____ / /__
/ _ / / // / _ \/ '_/
/____/_/\_, /_//_/_/\_\
/___/ v1.1.0 on Arduino Mega
#StandWithUkraine https://bit.ly/swua
[3482] Connecting to blynk.cloud:80
[4324] <[1D|00|01|00]
[4325] <*my auth token*
[10327] Login timeout
I looked at all previous questions from others regarding this same issue, but none of them seemed to make it work.
But the weird thing is, when I look in my Blynk.cloud the device keeps changing to online for a half second right before the Login timeout comes, so this cant be some connection problem I suppose. And I also tried it with my ESP8266, and it can connect normally to Blynk over Wi-Fi.
I first tried with my main code, and when that didn’t work, I tried it with the Blank example, that you can find in Blynk examples to eliminate any interference with the rest of my code. But also same issue
So if anyone can help me, it would be greatly appreciated.
PS. I also tried the different server, like suggested in some other question about this topic, but sadly to no avail
The code I was running:
#define BLYNK_TEMPLATE_ID "*redacted*"
#define BLYNK_DEVICE_NAME "*redacted*"
#define BLYNK_AUTH_TOKEN "*redacted*"
#define Blynk_DEBUG
#include <UIPEthernet.h>
#include <BlynkSimpleUIPEthernet.h>
Blynk.begin(auth, "blynk-cloud.com", 8080);
//Blynk.begin(auth, IPAddress(192,168,1,100), 8080);
// to avoid delay() function!
