Hello! I have a project in witch i want to open doors using servomotors and ir sensors, i have 4 of each. I try to create functions for each door and use milies() do create a delay for the door to stay open for a bit . but only one door ,function “usa_camera” is working , and i don’t why the others don’t.
Here is the code:
#include<Servo.h>
Servo usca; //servomotor camera
Servo usba; //servomotor baie
Servo usbuc; //servomotor bucatarie
Servo usfa; //servomotor fata
int ir1=22; // senzor camera
int ir2=23; // senzor baie
int ir3=24; // senzor bucatarie
int ir4=25; // senzor fata
const int interval=5000;
unsigned long alta=0; //Memoreaza timpul
usca.attach(12);
usba.attach(11);
usbuc.attach(5);
usfa.attach(9);
usca.write(170);
usba.write(180);
usbuc.write(0);
usfa.write(180);
pinMode(ir1,INPUT);
pinMode(ir2,INPUT);
pinMode(ir3,INPUT);
pinMode(ir4,INPUT);
unsigned long timp= millis();
usa_camera(timp);
usa_baie(timp);
usa_bucatarie(timp);
usa_fata(timp);
//////////Usa Camera
void usa_camera(int timp)
if(digitalRead(ir1)==0)
usca.write(60);
else if(digitalRead(ir1)==1)
{if(timp-alta>=interval)
alta=timp;
usca.write(170);
//////////Usa Baie
void usa_baie( int timp)
if(digitalRead(ir2)==0)
usba.write(60);
else if(digitalRead(ir2))
alta=timp;
usba.write(180);
////// //Usa Bucatarie
void usa_bucatarie(int timp)
if(digitalRead(ir3)==1)
usbuc.write(120);
else if(digitalRead(ir3)==0)
{ if(timp-alta>=interval)
alta=timp;
usbuc.write(0);
///////////Usa Fata
void usa_fata(int timp)
if(digitalRead(ir4)==1)
usfa.write(180);
else if(digitalRead(ir4)==0)
alta=timp;
usfa.write(70);
