Hello good night again I with problems
I am having problems with my arduino mega and my relays (digital outputs)
It’s weird, some of them are not … I can not make more than 4 digital outputs of the 53 work.
Example
http://kevinescudero.net:8080/xxxxxxxxxxxxx3/update/D31?value=0 http://kevinescudero.net:8080/xxxxxxxxxxxxx3/update/D31?value=1
its WORK.
But
BLYNK_WRITE(V25) {
EstadoAperturaPorton = param.asInt();
digitalWrite(AperturaPorton, EstadoAperturaPorton);
It does not work, when I click on the APP the “Arduino receives, because I made a few PRINTS but it does not do anything about the pin …”
It’s very strange…
Test up by putting this directly in the SETUP:
And it does not work either …
Full Code
#include <Ethernet.h>
#include <DHT.h>
#include <Wire.h>
#include <DHT.h>
#include <TimeLib.h>
#include <WidgetRTC.h>
char auth[] = "xxxxxxxxxxxxxxxx";
#define W5100_CS 10
#define SDCARD_CS 4
#define DHTPIN 23
DHT dht(DHTPIN, DHTTYPE);
WidgetRTC rtc;
WidgetTerminal terminal(V100);
bool isFirstConnect = true;
const int SensorPorton = 8; //
const int SensorBombaAgua = 7; //
const int BotonCuarto = 6;
const int ReflectorPorton = 5;
const int ReflectorTerreno = 4;
const int AperturaPorton = 31;
const int LuzCuarto = 2;
const int ReflectorPatio = 45; //
const int BombaAgua = 41; //
const int BombaPresurizadora = 43; //
int EstadoLuzCuarto, EstadoBotonCuarto,EstadoReflectorPorton,EstadoReflectorTerreno,EstadoAperturaPorton,EstadoSensorPorton,EstadoBombaAgua,EstadoSensorBombaAgua,EstadoReflectorPatio,EstadoBombaPresurizadora;
BLYNK_CONNECTED() {
if (isFirstConnect) {
Blynk.syncAll();
isFirstConnect = false;
BLYNK_WRITE(V0) {
EstadoLuzCuarto = param.asInt();
digitalWrite(LuzCuarto, EstadoLuzCuarto);
BLYNK_WRITE(V3) {
EstadoReflectorPorton = param.asInt();
digitalWrite(ReflectorPorton, EstadoReflectorPorton);
BLYNK_WRITE(V4) {
EstadoReflectorTerreno = param.asInt();
digitalWrite(ReflectorTerreno, EstadoReflectorTerreno);
BLYNK_WRITE(V5) {
EstadoReflectorPatio = param.asInt();
digitalWrite(ReflectorPatio, EstadoReflectorPatio);
BLYNK_WRITE(V6) {
EstadoBombaAgua = param.asInt();
digitalWrite(BombaAgua, EstadoBombaAgua);
BLYNK_WRITE(V7) {
EstadoSensorPorton = param.asInt();
BLYNK_WRITE(V25) {
BLYNK_WRITE(V9) {
EstadoSensorBombaAgua = param.asInt();
BLYNK_WRITE(V10) {
EstadoBombaPresurizadora = param.asInt();
digitalWrite(BombaPresurizadora, EstadoBombaPresurizadora);
void checkbotones()
if (digitalRead(BotonCuarto) == LOW) {
if (EstadoBotonCuarto != LOW) {
EstadoLuzCuarto = !EstadoLuzCuarto;
Blynk.virtualWrite(V0, EstadoLuzCuarto);
EstadoBotonCuarto = LOW;
EstadoBotonCuarto = HIGH;
void temperaturayhumedad()
float h = dht.readHumidity();
if (isnan(h) || isnan(t)) {
String currentDate = String(day()) + "/" + month() + "/" + year();
terminal.println("Error Temperatura Cuarto Kevin: ");
terminal.print(currentTime);
terminal.print(" ");
terminal.print(currentDate);
terminal.println();
terminal.flush();
return;
Blynk.virtualWrite(V2, h);
Blynk.virtualWrite(V1, t);
void checkconnect()
bool result = Blynk.connected();
if (result == false) {
Blynk.connect();
Serial.println("Reconectando");
pinMode(SDCARD_CS, OUTPUT);
digitalWrite(SDCARD_CS, HIGH);
Blynk.begin(auth, IPAddress(192, 168, 1, 14), 8080);
dht.begin();
rtc.begin();
pinMode(LuzCuarto, OUTPUT);
pinMode(ReflectorPorton, OUTPUT);
pinMode(ReflectorTerreno, OUTPUT);
pinMode(BombaAgua, OUTPUT);
pinMode(ReflectorPatio, OUTPUT);
pinMode(BotonCuarto, INPUT_PULLUP);
pinMode(SensorPorton, INPUT_PULLUP);
pinMode(SensorBombaAgua, INPUT_PULLUP);
terminal.println(F("Blynk v" BLYNK_VERSION ": Device started"));
terminal.println(F("-------------"));
terminal.flush();
timer.setInterval(100L, checkbotones);
timer.setInterval(100000L, temperaturayhumedad);
timer.setInterval(1000L, checkconnect);
EDIT:
I test this and Work Too ![]()
http://kevinescudero.net:8080/0xxxxxxxx3/update/V25?value=1
http://kevinescudero.net:8080/0xxxxxxxxx3/update/V25?value=0
