Arduino Mega cant connect to blynk server
please help me! I can’t connect my Arduino Mega to blynk, even though my source code Arduino already has ‘Done Uploading’. and the problem is:
[1[9]
___ __ __
/ _ )/ /_ _____ / /__
/ _ / / // / _ / '/
//_, /////_
__/ v0.6.1 on Arduino Mega
[100] Con2:Tembok Wifi
[1133] Fail2Rst
[11143] FailW
I connecting Arduino Mega 2560 to ESP8266 ESP01 which upgraded version. anybody know how to solve my problem?:frowning:
Hi, you need to post your code . . .
cul
billd
You also need to provide detailed information about how you have connected your Arduino Mega and ESP-01 together.
i connected Arduino Mega 2560 to ESP01.
ESP01 pin --> Arduino Mega
TX --> RX
RX --> TX
VCC --> 3.3V
CH_EN --> 3.3V
GND --> GND
do you know my problem? i can’t find it :frowning:
The TX and RX pins on the Mega are best used for serial debugging, so you’d be better off using one of te other three serial ports on the Mega for your connection to the ESP-01.
Read this for more info (Yes, it’s about connecting a Bluetooth module rather than an ESP-01, but the same issues remain):
You’ll obviously need to amend the sketch that you upload to the Mega (which @Bill_Donnelly has asked you to post, but which you haven’t) .
please help me! I can’t connect my Arduino Mega to blynk, even though my source code Arduino already has ‘Done Uploading’. the source code is:
#include <ESP8266_Lib.h>
char auth[] = "q7uYUIAuDGELS0ImHQCvvVSnir8aLeGZ";
char ssid[] = "Tembok Wifi";
char pass[] = "1sampai8";
#define EspSerial Serial1
//#include <SoftwareSerial.h>
//SoftwareSerial EspSerial(17, 18); // RX, TX
// Your ESP8266 baud rate:
#define ESP8266_BAUD 9600
ESP8266 wifi(&EspSerial);
  // Set ESP8266 baud rate
  //Blynk.begin(auth, wifi, ssid, pass, "blynk-cloud.com", 80);
  //Blynk.begin(auth, wifi, ssid, pass, IPAddress(192,168,1,100), 8080);
  // to avoid delay() function!
 and the problem is:
[1[9]
___ __ __
/ _ / / // / _ / ' <em>/
/</em> ***/* /_, /* //* / <em>/_
/</em> __/ v0.6.1 on Arduino Mega
[1133] Fail2Rst
[11143] FailW
TX --> RX
RX --> TX
VCC --> 3.3V
CH_EN --> 3.3V
GND --> GND
does anybody know how to solve my problem? i can't find it. :frowning:
@vikalaeli please edit your post, using the pencil icon at the bottom, and add triple backticks at the beginning and end of your code so that it displays correctly.
I’ve merged this into the previous topic you created on this subject- please don’t keep creating new topics on the same subject otherwise your forum account will be suspended.
I’ve already told you what the first step towards resolving this issue is, but you’ve ignored that advice. Is there any reason why?
Please change your ESP buadrate to 9600 if you’re using the sofwtare serial
refer to : http://help.blynk.cc/en/articles/605485-esp8266-with-at-firmware
