Hey there Blynkers!
here is a video of my latest project using Blynk:
An arduino pro micro connected to an Esp8266 sending Keyboard commands to the computer over Wifi! hope you enjoy it
Arduino Keyboard commands using Esp8266 and Blynk
This is freaking cool! I was waiting for someone to control computer with Blynk!
Thank you for sharing! May be you can share the link to the code you are using? Someone would be definitely interested in it.
very nice would be interested to see the code also …
I will post the code here in the next couple of days.
Thanks for the support and i’m looking forward to getting my hands on more widgets!
Hey guys, this is the code to the project, just be sure to change the Authentication toke, ssid, password
and to add buttons on your app from pins V0 to V15:
/* this code is for the Esp-201.
connections:
Arduino --------------------------- Esp-201
VCC-----Voltage Regulator-----VCC/3.3V
VCC----Voltage Regulator—CH_PD
GND---------------------------GND
GND---------------------------GPIO15
GPIO10------------------------GPIO2
GPIO7-------------------------GPIO13
GPIO6-------------------------GPIO12
GPIO5-------------------------GPIO14
GPIO2-------------------------GPIO5
int pins ={5,14,12,13};
int decide = 2;
char auth = “your authentication code”;
String str=“”;
BLYNK_WRITE(0) // Virtual pin 0
if(param.asInt()!=0){
activate(0);
BLYNK_WRITE(1) // Virtual pin 1
activate(1);
BLYNK_WRITE(2) // Virtual pin 2
activate(2);
BLYNK_WRITE(3) // Virtual pin 3
activate(3);
BLYNK_WRITE(4) // Virtual pin 4
activate(4);
BLYNK_WRITE(5) // Virtual pin 5
activate(5);
BLYNK_WRITE(6) // Virtual pin 6
activate(6);
BLYNK_WRITE(7) // Virtual pin 7
activate(7);
BLYNK_WRITE(8) // Virtual pin 8
activate(8);
BLYNK_WRITE(9) // Virtual pin 9
activate(9);
BLYNK_WRITE(10) // Virtual pin 10
activate(10);
BLYNK_WRITE(11) // Virtual pin 11
activate(11);
BLYNK_WRITE(12) // Virtual pin 12
activate(12);
BLYNK_WRITE(13) // Virtual pin 13
activate(13);
BLYNK_WRITE(14) // Virtual pin 14
activate(14);
BLYNK_WRITE(15) // Virtual pin 15
activate(15);
pinMode(decide,OUTPUT);
digitalWrite(decide,LOW);
Blynk.begin(auth, “your ssid”, “your password”);
void activate(int x){ // this function receives a number, turns it into a binary string and lights up the corresponding pins.
str = String(x,BIN);
for(int i = 0; i <(sizeof(pins)/sizeof(int));i++){ // first turn them all LOW
pinMode(pins[i],OUTPUT);
digitalWrite(pins[i],LOW);
for(int i = 0;i<str.length();i++){ // turn HIGH the ones that should be on if(str.charAt(str.length()-1-i)=='1') digitalWrite(pins[i],HIGH); } digitalWrite(decide,HIGH); delay(10); digitalWrite(decide,LOW);}
and the code for the arduino pro micro:
/* this code is for the Arduino pro micro.
connections:
Arduino Esp-201
VCC----Voltage Regulator-----CH_PD
int pins [] ={2,5,6,7};
int decide=10;
String str="";
String text = "";
int x;
pinMode(pins[i],INPUT);
pinMode(decide,INPUT);
while(digitalRead(decide)==1){}
int x= digitalRead(decide);
if(x==1){
for(int i = 0; i<(sizeof(pins)/sizeof(int));i++){
if(digitalRead(pins[i])==1)
str="1"+str;
str="0"+str;
x=((((int)str.charAt(0))-48)*8)+((((int)str.charAt(1))-48)*4)+((((int)str.charAt(2))-48)*2)+((((int)str.charAt(3))-48)*1); //convert the Esp-201 pin values to a binary string
action(x);
str="";
void action(int x){
switch(x){ //this is where you put your different Keyboard functions, correlating to the corresponding button on the Blynk app.
case 0: // Tab key
Keyboard.write(KEY_TAB);
break;
case 1: // Up Arrow
Keyboard.write(KEY_UP_ARROW);
break;
case 2: // Hello World
Keyboard.print("HELLO WORLD ");
break;
case 3: // Select All
Keyboard.press(KEY_LEFT_CTRL );
Keyboard.write('a');
Keyboard.release(KEY_LEFT_CTRL );
break;
case 4: // Left Arrow
Keyboard.write(KEY_LEFT_ARROW);
break;
case 5: // Down Arrow
Keyboard.write(KEY_DOWN_ARROW);
break;
case 6: // Right Arrow
Keyboard.write(KEY_RIGHT_ARROW);
break;
case 7: // Change language
Keyboard.press(KEY_LEFT_SHIFT);
Keyboard.write(KEY_LEFT_ALT);
Keyboard.release(KEY_LEFT_SHIFT);
break;
case 8: // Press Enter
Keyboard.write(KEY_RETURN);
break;
case 9: // Press Backspace
Keyboard.write(KEY_BACKSPACE);
break;
case 10:
break;
case 11:
break;
case 12: // Open notepad
Keyboard.press(KEY_LEFT_GUI);
Keyboard.write('r');
Keyboard.release(KEY_LEFT_GUI);
delay(100);
Keyboard.print("notepad");
break;
case 13: // Matrix text
text = "Wake up, Neo...";
type(text);
delay(3000);
for(int i = 0;i < text.length();i++){
text = "The Matrix has you...";
type(text);
delay(3000);
text = "Follow the white rabbit.";
type(text);
delay(3000);
text = "Knock, knock, Neo.";
type(text);
delay(3000);
break;
case 14:// Close window
Keyboard.press(KEY_LEFT_ALT);
Keyboard.write(KEY_F4);
Keyboard.release(KEY_LEFT_ALT);
break;
case 15:
break;
void type(String str){
for(int i=0;i<str.length();i++){
Keyboard.write(str.charAt(i));
delay(75);
enjoy.
Hi, I am trying to compile your code using the Arduino IDE 1.6.4 and selecting the generic ESP8266 as the target board, but the compiling process fails:
Build options changed, rebuilding all
In file included from /Users/lveronese/Documents/Arduino/libraries/blynk-library-0.2.1/BlynkSimpleEsp8266.h:15:0,
from ESP8266_Standalone.ino:26:
/Users/lveronese/Documents/Arduino/libraries/blynk-library-0.2.1/BlynkApiArduino.h:44:6: warning: always_inline function might not be inlinable [-Wattributes]
void BlynkApi::processCmd(const void* buff, size_t len)
In file included from /Users/lveronese/Documents/Arduino/libraries/blynk-library-0.2.1/BlynkSimpleEsp8266.h:16:0,
/Users/lveronese/Documents/Arduino/libraries/blynk-library-0.2.1/Blynk/BlynkProtocol.h:159:6: warning: always_inline function might not be inlinable [-Wattributes]
void BlynkProtocol::processInput(void)
In file included from /Users/lveronese/Documents/Arduino/libraries/blynk-library-0.2.1/Blynk/BlynkDebug.h:17:0,
from /Users/lveronese/Documents/Arduino/libraries/blynk-library-0.2.1/utility/BlynkDebug.cpp:10:
/Users/lveronese/Library/Arduino15/packages/esp8266/hardware/esp8266/1.6.4-673-g8cd3697/tools/sdk//include/ets_sys.h:104:5: error: previous declaration of ‘int atoi(const char*)’ with ‘C++’ linkage
int atoi(const char *nptr);
In file included from /Users/lveronese/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9/xtensa-lx106-elf/include/stdint.h:12:0,
from /Users/lveronese/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9/lib/gcc/xtensa-lx106-elf/4.8.2/include/stdint.h:9,
from /Users/lveronese/Library/Arduino15/packages/esp8266/hardware/esp8266/1.6.4-673-g8cd3697/tools/sdk//include/c_types.h:8,
from /Users/lveronese/Library/Arduino15/packages/esp8266/hardware/esp8266/1.6.4-673-g8cd3697/tools/sdk//include/ets_sys.h:11,
from /Users/lveronese/Documents/Arduino/libraries/blynk-library-0.2.1/Blynk/BlynkDebug.h:17,
/Users/lveronese/Library/Arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9/xtensa-lx106-elf/include/stdlib.h:70:5: error: conflicts with new declaration with ‘C’ linkage
int _EXFUN(atoi,(const char *__nptr));
/Users/lveronese/Library/Arduino15/packages/esp8266/hardware/esp8266/1.6.4-673-g8cd3697/tools/sdk//include/ets_sys.h:119:6: error: previous declaration of ‘void ets_intr_lock()’ with ‘C++’ linkage
void ets_intr_lock();
In file included from /Users/lveronese/Documents/Arduino/libraries/blynk-library-0.2.1/Blynk/BlynkDebug.h:26:0,
/Users/lveronese/Library/Arduino15/packages/esp8266/hardware/esp8266/1.6.4-673-g8cd3697/cores/esp8266/Arduino.h:122:20: error: conflicts with new declaration with ‘C’ linkage
/Users/lveronese/Library/Arduino15/packages/esp8266/hardware/esp8266/1.6.4-673-g8cd3697/tools/sdk//include/ets_sys.h:120:6: error: previous declaration of ‘void ets_intr_unlock()’ with ‘C++’ linkage
void ets_intr_unlock();
/Users/lveronese/Library/Arduino15/packages/esp8266/hardware/esp8266/1.6.4-673-g8cd3697/cores/esp8266/Arduino.h:123:22: error: conflicts with new declaration with ‘C’ linkage
Error compiling.
It seems the include file is wrong, but I have no clues about how to fix it: can you help me ?
Thanks a lot
Luciano
is this the first time your’e compiling with the 1.6.4 ide?
try going to the BlynkDebug.h file and commenting out these 2 lines:
#ifdef ESP8266
// #include "ets_sys.h"
// #include "os_type.h"
#include "mem.h"
#else
worked for me, let me know if it worked
Well, now the program compiles, but I have warnings:
In file included from /Users/lveronese/Documents/Arduino/libraries/blynk-library/BlynkSimpleEsp8266.h:15:0,
from ESP8266_Standalone.ino:27:
/Users/lveronese/Documents/Arduino/libraries/blynk-library/BlynkApiArduino.h:44:6: warning: always_inline function might not be inlinable [-Wattributes]
In file included from /Users/lveronese/Documents/Arduino/libraries/blynk-library/BlynkSimpleEsp8266.h:16:0,
/Users/lveronese/Documents/Arduino/libraries/blynk-library/Blynk/BlynkProtocol.h:161:6: warning: always_inline function might not be inlinable [-Wattributes]
I am wondering what the changes you suggest actually do…
I did not specify in my previous post that I am using the standard 1.6.4 Arduino IDE and the board file specified here https://github.com/esp8266/Arduino.
Do you have warnings ? And what IDE do you use?
Luciano
I actually dont know what they do, I’m also using the Arduino Ide 1.6.4 and followed a post here and that’s the only way it worked for me.
Why do you need the arduino micro at all? Couldn’t you just have everything done on the ESP?
Because the esp can’t send keystrokes to the computer
Sorry for stealing this old thread but I can’t find what I want.
I would like to do exactly the inverse of this, I would like to use my keyboard of gamepad that are connected to my desktop to send commands to the ESP8266.
Does any of you have some hints?
Thank you in advance
I would recommend you creating a new topic.
