BLYNK
Arduino IDE: Tools -> Blynk: Check for Updates results in an Exception
arduino
#1
No idea if this is an Arduino IDE issue or a Blynk issue.
In Arduino IDE version 1.8.9 (on Windows 64 bit) with Blynk version 0.6.1 installed, if I select:
An exception is thrown:
Downloading ‘https://raw.githubusercontent.com/blynkkk/blynk-library/master/library.properties
… done.
Latest version: 0.6.1
Exception in thread “Thread-30” java.lang.NoClassDefFoundError: cc/arduino/contributions/filters/InstalledPredicate
at com.github.blynk.arduino.tools.BlynkUpdater.lambda$run$0(BlynkUpdater.java:144)
at java.lang.Thread.run(Thread.java:748)
#2
I seem to recall Blynk disregarding this method of Library update due to “issues”… but they clearly never removed its availability (in the IDE).
#4
I wonder if this exception is due to having already installed Library 0.6.1? as I do, and also get the same exception when rechecking.
I personally just use the officially recommended manual install.
