I have the problem that my board disconnects after a very short time. It will not be due to a same MAC address. I have tested the board as a single user on the router and tried several Mac addresses. Whether I take the domain or the IP from the Blynk Cloud also changes nothing.
Social networks: http://www.fb.com/blynkapp
http://twitter.com/blynk_app
This example shows how to configure static IP with Ethernet.
Be sure to check ordinary Ethernet example first!!!
NOTE: Pins 10, 11, 12 and 13 are reserved for Ethernet module.
DON'T use them in your sketch directly!
WARNING: If you have an SD card, you may need to disable it
by setting pin 4 to HIGH. Read more here:
https://www.arduino.cc/en/Main/ArduinoEthernetShield
#include <Ethernet.h>
char auth[] = "";
IPAddress server_ip (139, 59, 206,133 );
// Mac address should be different for each device in your LAN
byte arduino_mac[] = { 0xDE, 0xED, 0xBA, 0xFE, 0xFE, 0xED };
IPAddress arduino_ip ( 192, 168, 178, 90);
IPAddress dns_ip ( 192, 168, 178, 1);
IPAddress gateway_ip ( 192, 168, 178, 1);
IPAddress subnet_mask(255, 255, 255, 0);
#define W5100_CS 10
#define SDCARD_CS 4
int z;
pinMode(SDCARD_CS, OUTPUT);
digitalWrite(SDCARD_CS, HIGH); // Deselect the SD card
Blynk.begin(auth, server_ip, 8080, arduino_ip, dns_ip, gateway_ip, subnet_mask, arduino_mac);
// Or like this:
//Blynk.begin(auth, "blynk-cloud.com", 80, arduino_ip, dns_ip, gateway_ip, subnet_mask, arduino_mac);
