Arduino + ESP8266 + blynk
vhymanskyy
I auditioned , is working perfectly with this new update !
Congratulations friend! Success Blynk ! LoL !
can you please provide that library,
So, Janis, have you found a solution? I have the same trouble…
All new modules ESP-01 I have had the same problem. To communicate with ESP I used hard serial of UNO and libraries <ESP8266_HardSer.h> <BlynkSimpleShieldEsp8266_HardSer.h>
I the problem solved by setting the pre-configuration of the ESP program by “ESP8266 Config.exe.”
I set operating mode = STA and put a name and password for the network to which to connect has ESP.
From that moment all ESP work properly in projects.
All new modules ESP-01 I have had the same problem. To communicate with ESP I used hard serial of UNO and libraries ESP8266_HardSer.h BlynkSimpleShieldEsp8266_HardSer.h
how did you do it? With the Arduino R3 connected with ESP8266 or with USB Adapter?
USB adapter 5 V (CH340) with resistors 470om and 1k divisor on Rx input ESP to fit 3,3 V level.
