Try this sketch (without email) that includes PIR and tone etc.
Remember to include your working token before the upload to Arduino.
#define BLYNK_PRINT SwSerial
int ledPin = 13; // choose the pin for the LED
int inputPin = 2; // choose the input pin (for PIR sensor)
int pirState = LOW; // we start, assuming no motion detected
int val = 0; // variable for reading the pin status
int pinSpeaker = 10; //Set up a speaker on a PWM pin (digital 9, 10, or 11)
void myTimerEvent()
val = digitalRead(inputPin); // read input value
if (val == HIGH) { // check if the input is HIGH
digitalWrite(ledPin, HIGH); // turn LED ON
playTone(300, 160);
delay(150);
if (pirState == LOW) {
// we have just turned on
Serial.println("Motion detected!");
// We only want to print on the output change, not state
pirState = HIGH;
digitalWrite(ledPin, LOW); // turn LED OFF
playTone(0, 0);
delay(300);
if (pirState == HIGH){
// we have just turned of
Serial.println("Motion ended!");
pirState = LOW;
// duration in mSecs, frequency in hertz
void playTone(long duration, int freq) {
duration *= 1000;
int period = (1.0 / freq) * 1000000;
long elapsed_time = 0;
while (elapsed_time < duration) {
digitalWrite(pinSpeaker,HIGH);
delayMicroseconds(period / 2);
digitalWrite(pinSpeaker, LOW);
elapsed_time += (period);
pinMode(ledPin, OUTPUT); // declare LED as output
pinMode(inputPin, INPUT); // declare sensor as input
pinMode(pinSpeaker, OUTPUT);
SwSerial.begin(9600);
Blynk.begin(Serial, auth);
// Setup a function to be called every 437ms
timer.setInterval(437L, myTimerEvent);
i am not sure i took out the buzzer, in my final thing i want to have a buzzer if thats fine. I dont think the PIR sensor works as whenever i move infront of it it does not light up the LED.
Add a Blynk LED on V0 and add the email widget to your project.
Then try this sketch without buzzer but with PIR and email.
Enter your email address in the sketch and your token.
// PIR4Blynker.ino on Arduino
long lastTrigger; // wait at least 15s before sending email / push again
unsigned int pir = LOW; // declare variable to store PIR status
char Mail[] = "xxxxxxxxx"; // ENTER YOUR EMAIL ADDRESS
String Subject = "PIR Activated"; // subject message
String MsgBody = "Intruder detected"; // message content
void myTimerEvent()
pir = digitalRead(inputPin);
if (pir == HIGH) // If alarm enabled
Blynk.virtualWrite(V0, 255);
if(lastTrigger == 0 || millis() > lastTrigger + 15123L)
Blynk.email(Mail, Subject, MsgBody);
lastTrigger = millis();
Blynk.virtualWrite(V0, 0);
// Setup a function to be called every 473ms
timer.setInterval(473L, myTimerEvent);
I can see that the PIR sensor is working and the led is working. The problem is the value is not going up on the blynk app and i am not getting the email.
I am not sure what happened but right now my system on terminal is reconnecting which means it is not connected to blynk app i think overtime it will connect back
I have entered the email in the sketc, i have still didnt receive any emails i think i have google email which can cause a problem maybe i have to check the settings?
The LED the physical one was working as well as the small orange one on the arduino is blinking.
char auth[] = "BYE-hacker";
char Mail[] = "secret"; // ENTER YOUR EMAIL ADDRESS
String Subject = "Security Notice"; // subject message
String MsgBody = "Intruder has Been Detected"; // message content
void myTimerEvent()
I am not testing it, that will be a hacker because you keep posting your token in a public forum.
As you don’t have a USB2TTL adaptor and there is a conflict with your pinspeaker I have revised the sketch.
Again add email address and use a new token but send it to me for testing.
//#define BLYNK_PRINT SwSerial
//#include <SoftwareSerial.h>
//SoftwareSerial SwSerial(6, 11); // RX, TX
void myTimerEvent()
//SwSerial.begin(9600);
