Blynk works just fine with Arduino Create (web-based development platform from Arduino that allows you to write and upload sketches, share, and collaborate).
It looks like the Arduino IDE but web-based. I’ll pass, thanks I’ll use PlatformIO and github for creating shared stuff and collaborating. Works much better probably
although, i tried several online services, like: ide, pcb design, drawing, etc, i generally stay away from any online “tools”. the reasons are as follow:
they are always much slower / wobbling than dedicated and locally installed software
implicitly won’t work without internet → more dependency
a lots of display area is wasted because of the browser → less useful work surface
not hackable - and i do not mean piracy, but configuration
much more wasted energy and resources from both sides (they need to run the servers, all my data has to travel back and forth across the globe, plus i observed (much) higher current consumption also on the laptop)
again, a new place to register, create account, log in, etc
only god knows who has access to your code / token / wifi credentials, etc
can’t manage and store the libs locally
i think dedicated softwares are generally more robust and productive
but versus the above reasons, what are the benefits?
You can access it anywhere with Internet. But as for your arguments, I totally agree with you @wanek. Latency could be an issue, but my main concern is security
