Hello everyone,
Android 7.0, Redmi Note4. Blynk 2.20.3
Application will freeze at startup. The problem is probably in Superchart. Probably wrong axis settings). How can I delete Superchart widget from PC?
Do you mean the App in its entirety freezes up, or just when accessing a particular project… do you have more then one project?
What do you meen delete the widget from the PC? Are you running a Local Server on your PC?
