App ui error
when i delete the elements in Device tiles -> Template1->Elements ( buttons , charts ) ( build - platform = android , app. versioning =2.17.0 ) , it restores automatically and it appears again.
when i downgrade the app to 2.16.1 ( android ) , the elements completely removed and it is not appearing again.
Thanks for the report. Do you remove template or just widgets within template?
@Dmytro , i just removed the widgets inside the template ! , i also found that - when i renamed a label data or colour of the widgets , it restore to its previous values
Untitled
the values also disappear in widgets name and ranges
@Dmytro we have tried using our own hosted server as well as the blynk server and we are having the same problem sir .
Guys, thanks for your reports. This issue will be fixed in 2.17.1 release, that should be available soon.
@BlynkAndroidDev thank you very much !
@BlynkAndroidDev sir , the pin values gone bug is solved in this update , but the widgets are unable to delete in device tiles template . thank you !
Ou, I’ve missed mentions about delete bug. We’ll check and fix in a new release.
We are releasing a small update today (but with same version name 2.17.1) - it will contain a fix to widget’s removal from templates. Just check the google play in several hours.
@BlynkAndroidDev thankyou for update !
