#I have followed the instrctions perfect I am new to this please help In the app it says device is online but #the joystick does nothing I have tried 4 aa baterries and a 9v battery. I hope I posted this right.
#this is the name of the project I found online
Simplest Wifi Car Using ESP8266 Motorshield
char pass[] = "YourPassword";
int PWMA=5;//Right side
int PWMB=4;//Left side
int DA=0;//Right reverse
int DB=2;//Left reverse
void setup(){
pinMode(PWMA, OUTPUT);
pinMode(PWMB, OUTPUT);
pinMode(DA, OUTPUT);
pinMode(DB, OUTPUT);
void loop(){
// Handling Joystick data
BLYNK_WRITE(V1){
int x = param[0].asInt();
int y = param[1].asInt();
if(x==-1 && y==-1){ //Backward and Left
digitalWrite(PWMA, LOW);
digitalWrite(DA, LOW);
digitalWrite(PWMB, HIGH);
digitalWrite(DB, HIGH);
}else if(x==-1 && y==0){ //Left Turn
digitalWrite(PWMA, 450);
digitalWrite(DA, HIGH);
digitalWrite(PWMB, 450);
digitalWrite(DB, LOW);
}else if(x==-1 && y==1){ //Forward and Left
}else if(x==0 && y==-1){ //Backward
digitalWrite(PWMA, HIGH);
}else if(x==0 && y==0){ //Stay
digitalWrite(PWMB, LOW);
}else if(x==0 && y==1){ //Forward
}else if(x==1 && y==-1){ //Backward and Right
}else if(x==1 && y==0){ //Right turn
}else if(x==1 && y==1){ //Forward and Right
