I just started with Blynk again after some weeks, my app and esp2866 server still worked fine. Then I noticed the updates to the app, and just updated from the Play Store. Now the app displays “reconnecting to server” all the time, about every second. I becomes pretty much unusable because of that. This is already in the main screen where all the projects are displayed, it has nothing to do with a specific project.
Why is it disconnecting/reconnecting to the Blynk server all the time? This is on a Galaxy S3. Is there a way to downgrade the app so it works again?
I just found the error, I had actually setup a local server and forgot about that. I updated the server, and now I hope it works. Sorry!
However I just tried to use the admin website to change the password for the user on my local server, and I think there may be a real bug there. I changed the password and then clicked ‘save’ at the bottom of the page, but I get a message ‘Oops, an error occured : (code: -1) null’. The log contains the following:
14:28:05.302 ERROR - DecoderException. io.netty.handler.codec.DecoderException: java.lang.NullPointerException at io.netty.handler.codec.ByteToMessageDecoder.callDecode(ByteToMessageDecoder.java:418) at io.netty.handler.codec.ByteToMessageDecoder.channelRead(ByteToMessageDecoder.java:245) at io.netty.channel.AbstractChannelHandlerContext.invokeChannelRead(AbstractChannelHandlerContext.java:292) at io.netty.channel.AbstractChannelHandlerContext.fireChannelRead(AbstractChannelHandlerContext.java:278) at io.netty.channel.DefaultChannelPipeline.fireChannelRead(DefaultChannelPipeline.java:962) at io.netty.channel.nio.AbstractNioByteChannel$NioByteUnsafe.read(AbstractNioByteChannel.java:131) at io.netty.channel.nio.NioEventLoop.processSelectedKey(NioEventLoop.java:528) at io.netty.channel.nio.NioEventLoop.processSelectedKeysOptimized(NioEventLoop.java:485) at io.netty.channel.nio.NioEventLoop.processSelectedKeys(NioEventLoop.java:399) at io.netty.channel.nio.NioEventLoop.run(NioEventLoop.java:371) at io.netty.util.concurrent.SingleThreadEventExecutor$2.run(SingleThreadEventExecutor.java:112) at io.netty.util.concurrent.DefaultThreadFactory$DefaultRunnableDecorator.run(DefaultThreadFactory.java:137) at java.lang.Thread.run(Thread.java:744) Caused by: java.lang.NullPointerException at java.lang.System.arraycopy(Native Method) at com.sun.crypto.provider.GCTR.reset(GCTR.java:125) at com.sun.crypto.provider.GCTR.doFinal(GCTR.java:116) at com.sun.crypto.provider.GaloisCounterMode.doLastBlock(GaloisCounterMode.java:343) at com.sun.crypto.provider.GaloisCounterMode.decryptFinal(GaloisCounterMode.java:511) at com.sun.crypto.provider.CipherCore.finalNoPadding(CipherCore.java:1023) at com.sun.crypto.provider.CipherCore.doFinal(CipherCore.java:960) at com.sun.crypto.provider.AESCipher.engineDoFinal(AESCipher.java:479) at javax.crypto.CipherSpi.bufferCrypt(CipherSpi.java:830) at javax.crypto.CipherSpi.engineDoFinal(CipherSpi.java:730) at javax.crypto.Cipher.doFinal(Cipher.java:2416) at sun.security.ssl.CipherBox.decrypt(CipherBox.java:535) at sun.security.ssl.EngineInputRecord.decrypt(EngineInputRecord.java:216) at sun.security.ssl.SSLEngineImpl.readRecord(SSLEngineImpl.java:968) at sun.security.ssl.SSLEngineImpl.readNetRecord(SSLEngineImpl.java:901) at sun.security.ssl.SSLEngineImpl.unwrap(SSLEngineImpl.java:775) at javax.net.ssl.SSLEngine.unwrap(SSLEngine.java:624) at io.netty.handler.ssl.SslHandler.unwrap(SslHandler.java:1098) at io.netty.handler.ssl.SslHandler.unwrap(SslHandler.java:970) at io.netty.handler.ssl.SslHandler.decode(SslHandler.java:904) at io.netty.handler.codec.ByteToMessageDecoder.callDecode(ByteToMessageDecoder.java:387) ... 12 more
