Read this before creating new topic:
- Search forum for similar topics
- Check https://docs.blynk.io
- Add details :
• Hardware model + communication type. For example: ESP8266
• Smartphone OS (iOS or Android) + OS version
#include <Wire.h>
#define BLYNK_TEMPLATE_ID "TMPL3-d_7rFoR"
#define BLYNK_TEMPLATE_NAME "carparking"
// Pin Definitions for IR Sensors
#define IR_SENSOR_1_PIN 5 // IR sensor 1 connected to D1 pin
#define IR_SENSOR_2_PIN 4 // IR sensor 2 connected to D2 pin
// Blynk Auth Token (replace with your Blynk Auth Token)
char auth[] = "ol7iAM8MDfCnSGOQo4-_ptr7g4iw-Y0I" ; // Replace with your actual Auth Token
// Wi-Fi credentials
char ssid[] = "Devs";
char pass[] = "devanshu123";
// Parking status variables
bool isCarInSpot1 = false;
bool isCarInSpot2 = false;
Serial.begin(9600); // Start serial communication for debugging
// Set up IR sensor pins as input
pinMode(IR_SENSOR_1_PIN, INPUT);
pinMode(IR_SENSOR_2_PIN, INPUT);
// Connect to Wi-Fi
// Debugging Wi-Fi connection
Serial.println("Connecting to WiFi...");
Serial.println("Connected to Wi-Fi");
// Initialize parking spots status (No car)
Blynk.virtualWrite(V0, "Empty"); // Parking Spot 1
Blynk.virtualWrite(V1, "Empty"); // Parking Spot 2
Blynk.run(); // Blynk.run() is essential for maintaining the connection to Blynk app
// Debugging sensor states
Serial.println("Sensor 1: " + String(digitalRead(IR_SENSOR_1_PIN)));
Serial.println("Sensor 2: " + String(digitalRead(IR_SENSOR_2_PIN)));
// Check if a car is detected in Parking Spot 1
isCarInSpot1 = digitalRead(IR_SENSOR_1_PIN) == LOW; // Active-low sensor (car detected when LOW)
if (isCarInSpot1) {
Blynk.virtualWrite(V0, "Occupied"); // Update status on Blynk app for Spot 1
Blynk.virtualWrite(V0, "Empty"); // Update status on Blynk app for Spot 1
// Check if a car is detected in Parking Spot 2
isCarInSpot2 = digitalRead(IR_SENSOR_2_PIN) == LOW; // Active-low sensor (car detected when LOW)
if (isCarInSpot2) {
Blynk.virtualWrite(V1, "Occupied"); // Update status on Blynk app for Spot 2
Blynk.virtualWrite(V1, "Empty"); // Update status on Blynk app for Spot 2
delay(1000); // Delay to prevent constant polling (1 second)
blynk app show online but the output is not shown.
What type of account do you have (Free, Maker, Pro)?
If it’s a free account, when was it created?
Your code is very badly written, in quite a few ways.
Currently, your code does two Blynk.virtualWrites every second. This isn’t necessary, as you only need to change the status of V0 and V1 if they change, not once per second regardless of whether the value has changed.
The latest version of the Free subscription is limited to 30,000 messages exchanges between the server and all of your devices combined, every month.
The way your code is written, you would exceed that limit once your device has been online for 250 minutes (just over 4 hours).
I believe that the web console has a status bar which tells you the current message count.
Also, you shouldn’t use delays in your sketch, you should use BlynkTimer instead, and your void loop should only contain Blynk.run() and timer.run().
Read this for more info…
