App latency
Hello, I’m migrating to the new app and I’m acquiring the same data as the old one with the same refresh rates. I noticed that when I open the old Blynk app, the parameters update immediately to the last acquired parameter. The new app does not behave in the same way, in fact the updates happen several tens of seconds after I open the app.
Basically when I open the old app with a glance I read the status of the variables while with the new one I often have to wait.
thank you
Davide
Are you using android or ios?
android
hi, which version of the app are you using? Can you also send logs: About → Send logs → Select gmail → Send
App Version: 1.6.4 (96)
@DavideD I see log file has not been attached - can you share it via some cloud and send here as file in PM?
App Version Name: 1.6.4 (96)
Core Version Name: 4.6.4
built at 30.09.2022 11:07
OS API Level: 31
Model: SM-M515F
Manufacturer: samsung
Granted Permissions: android.permission.INTERNET, android.permission.ACCESS_WIFI_STATE, android.permission.CHANGE_WIFI_STATE, android.permission.ACCESS_NETWORK_STATE, android.permission.CHANGE_NETWORK_STATE, android.permission.WAKE_LOCK, android.permission.VIBRATE, android.permission.FOREGROUND_SERVICE, android.permission.REQUEST_IGNORE_BATTERY_OPTIMIZATIONS, android.permission.USE_BIOMETRIC, android.permission.USE_FINGERPRINT, android.permission.RECEIVE_BOOT_COMPLETED, com.google.android.c2dm.permission.RECEIVE, com.google.android.gms.permission.AD_ID, com.google.android.finsky.permission.BIND_GET_INSTALL_REFERRER_SERVICE, cloud.blynk.DYNAMIC_RECEIVER_NOT_EXPORTED_PERMISSION, com.android.vending.BILLING
