Hi, Im early stages of learning to use Blynk. I’m currently trying to learn how to use buttons etc. I’ve tried this example code to set up a basic step button on V1. The app just keeps saying the project is offline. I’m using an iPhone. Here is the code. minus my login details.
char auth[] = "GSjesgIpM6IHhW17gWcPAXwf9wIC62Rp";
char ssid[] = "";
char pass[] = "";
// in Blynk app writes values to the Virtual Pin V1
BLYNK_WRITE(V1)
// process received value
Serial.print(pinValue);
// to avoid delay() function!
load 0x4010f000, len 1392, room 16
tail 0
chksum 0xd0
csum 0xd0
v3d128e5c
~ld
[59] Connecting to BTHub6-P67Q
it made me realise it wasn’t connecting and only then did I realise (I’m embarrassed to say) I had made a typo on my SSID. I corrected it and now and it is connecting fine. Thanks again.
No problem!
I always like to use 74880 as my debug baud rate because you can see both the boot messages from the D1 Mini and the debug messages without having to switch rates in your serial monitor.
