Hi guys,
I’m trying to ise an apds9960 by sprkfun with an nodeMCU but I’m not sure how to connect it properly, the pins are diferent on the node, so where do I change to make it work?
Not a Blynk specific topic… However, it is an I2C based device, so look up your NodeMCU pinouts and wire it accordingly.
https://www.google.com/#q=nodemcu+pinout
https://www.google.com/#q=apds-9960+nodemcu
https://learn.sparkfun.com/tutorials/apds-9960-rgb-and-gesture-sensor-hookup-guide
I made the gesture ensor work!! but for some reason my node is constantly disconecting frm server? someone knows what might be?
Post your code (properly formatted), otherwise how will we be able to tell what the problem may be.
GestureTest.ino
APDS-9960 RGB and Gesture Sensor
Shawn Hymel @ SparkFun Electronics
May 30, 2014
https://github.com/sparkfun/APDS-9960_RGB_and_Gesture_Sensor
Tests the gesture sensing abilities of the APDS-9960. Configures
APDS-9960 over I2C and waits for gesture events. Calculates the
direction of the swipe (up, down, left, right) and displays it
on a serial console.
To perform a NEAR gesture, hold your hand
far above the sensor and move it close to the sensor (within 2
inches). Hold your hand there for at least 1 second and move it
away.
To perform a FAR gesture, hold your hand within 2 inches of the
sensor for at least 1 second and then move it above (out of
range) of the sensor.
Hardware Connections:
IMPORTANT: The APDS-9960 can only accept 3.3V!
Wemos Pin APDS-9960 Board Function
3.3V VCC Power
GND GND Ground
D3 SDA I2C Data
D1 SCL I2C Clock
D6 INT Interrupt
D7 - LED
Resources:
Include Wire.h and SparkFun_APDS-9960.h
Development environment specifics:
Written in Arduino 1.0.5
Tested with SparkFun Arduino Pro Mini 3.3V
This code is beerware; if you see me (or any other SparkFun
employee) at the local, and you've found our code helpful, please
buy us a round!
Distributed as-is; no warranty is given.
Modified for ESP8266 by Jon Ulmer Nov 2016
#include <Wire.h>
#include <SparkFun_APDS9960.h>
#include <IRremoteESP8266.h>
// Pins on wemos D1 mini
#define APDS9960_INT D6 //AKA GPIO12 -- Interupt pin
#define APDS9960_SDA D3 //AKA GPIO0
#define APDS9960_SCL D1 //AKA GPIO5
// Constants
// Global Variables
SparkFun_APDS9960 apds = SparkFun_APDS9960();
volatile bool isr_flag = 0;
char ssid[] = "Jeo";
char pass[] = "239239";
char auth[] = "66dfbbdca562ff8";
// Bridge widget on virtual pin 1
WidgetBridge bridge1(V1);
// Timer for blynking
// Place the AuthToken of the second hardware here
BLYNK_CONNECTED() {
bridge1.setAuthToken("4668802bd32066b92dd3");
//Start I2C with pins defined above
Wire.begin(APDS9960_SDA,APDS9960_SCL);
// Set interrupt pin as input
pinMode(APDS9960_INT, INPUT);
// Initialize Serial port
// Initialize interrupt service routine
attachInterrupt(APDS9960_INT, interruptRoutine, FALLING);
// Initialize APDS-9960 (configure I2C and initial values)
if ( apds.init() ) {
Serial.println(F("APDS-9960 initialization complete"));
Serial.println(F("Something went wrong during APDS-9960 init!"));
// Start running the APDS-9960 gesture sensor engine
if ( apds.enableGestureSensor(true) ) {
Serial.println(F("Gesture sensor is now running"));
Serial.println(F("Something went wrong during gesture sensor init!"));
if( isr_flag == 1 ) {
detachInterrupt(APDS9960_INT);
handleGesture();
isr_flag = 0;
void interruptRoutine() {
isr_flag = 1;
void handleGesture() {
if ( apds.isGestureAvailable() ) {
switch ( apds.readGesture() ) {
case DIR_UP:
bridge1.digitalWrite(4, HIGH);
break;
case DIR_DOWN:
bridge1.digitalWrite(4, LOW);
break;
case DIR_LEFT:
Serial.println("LEFT");
break;
case DIR_RIGHT:
Serial.println("RIGHT");
break;
case DIR_NEAR:
Serial.println("NEAR");
break;
case DIR_FAR:
bridge1.digitalWrite(5, LOW);
bridge1.virtualWrite(3, 1);
delay(50);
bridge1.virtualWrite(3, 0);
break;
default:
Serial.println("NONE");
I fixed the code formatting as per requirements for proper display
Without digging into your code, I would guess that the interrupt routine you have is still too-much-too-fast.
I would move it into a timer loop of it’s own, even something checking every 250ms is better than blocking or flooding the void loop()
how can I do it?
I suspect it is that other code within your loop(). Do Note, I do not have any experience with the sensor you are using, so this may or may not work. I have also heard that interrupts can be troublesome on ESP’s, although I do not really use them so this may be incorrect as well. RESEARCH.
Question, why the isr_flag? Could you not just put this code in the interrupt routine, and remove it from loop()? Like below:
handleGesture();
Then it would still run when the interrupt is triggered, but keep it from slowing down the BLYNK process.
You could maybe even take it a step further and put the code from the handleGesture() in the interrupt routine as well.
case DIR_UP:
break;
case DIR_DOWN:
break;
case DIR_LEFT:
break;
case DIR_RIGHT:
break;
case DIR_NEAR:
break;
case DIR_FAR:
//delay(50); //delays don't work in ISR
break;
default:
Although, ISR’s should be as short and as fast as possible. It’s worth a try though.
I saw that you have BlynkTimer timer; setup already, and timer.run() in the void loop()… so figured you already knew how to use it.
Try moveing your interrupt check routine into a void MyLoop() of it’s own and add a timer.setInterval(250L, MyLoop);
http://docs.blynk.cc/#blynk-firmware-blynktimer
As I said, I honestly haven’t dug into your code, so there may be much more to your issue as @Toro_Blanco suspects.
