I found the auth code from my project didn’t work. I had to connect Bluetooth with debug on so I could see the auth code being sent and use that. Bug in the app maybe?
I finally get the HM-10 working. The trick was to use the SoftwareSerial-example as base code instead of the HM-10 example code.
So my code now looks like this, and this works!:
* Downloads, docs, tutorials: http://www.blynk.cc
* Blynk community: http://community.blynk.cc
* Social networks: http://www.fb.com/blynkapp
* http://twitter.com/blynk_app
* This example shows how to use Serial BLE modules (HM-10, HC-08)
* to connect your project to Blynk.
* NOTE: BLE support is in beta!
//#define BLYNK_DEBUG
#include <BlynkApiArduino.h>
#include <Adapters/BlynkSerial.h>
typedef BlynkTransportSerial<SoftwareSerial> SwSerialConnection;
SwSerialConnection connection(SwSerial);
BlynkSerial<SwSerialConnection> Blynk(connection);
// This is for debug prints
After updating the app to the latest version, the problem is indeed solved. I added my example code here. Remark that I use SoftwareSerial and set the pins, I think this is easier for example code as I assume most will start like this.
SoftwareSerial SerialBLE(10, 11); // RX, TX
SerialBLE.begin(9600); // Set Serial baud rate
Blynk.begin(auth, SerialBLE);
