Exactly.
I already have 4 devices and 2 emulators with one device and emulator on one account and the rest on the other. I only get the notifications on the correct devices.
Now granted, each account is also on a separate server… but that was the way it was when I had the issue of every single device notifying me at the same time
ah, ok. that is a different story! i mean this issue if all users are on the same server.
Not recently, as that is a rare occurance for me, and the reason for the separate devices in the first place.
I will try it again, but if all my devices start hounding me… I will find you
than better not to try, just relax :))
i will be hope Fix this on Next release.
as:
Too late… but I can confirm the issue is server independent (unless @Costas’s Paris server is in on the conspiracy
) … which make sense as the notifications generated are from the phone and only triggered by the App.
Now I will do the suggested “short term fix” and see what happens
Nope… even rebooted the device that shouldnt be running notifications, nada.
But then I removed the offending notification widget from the project, and immediately put it back, and now all is well in the world of Gunner again
Notification only on the correctly logged in devices.
So @wanek and @sh.abar.mard try simply removing and replacing the Notification Widget and see if that helps (until a fix is released).
i do this 10 time. but … ![]()
until… (hope).
Just to reiterate… i did this AFTER doing all the tedious logging in, stopping, logging out, rebooting, etc… so perhaps one has to follow all the dance moves?
