Hello Everyone!
I have a question. im trying to read multiple analog sensors with a multiplexer on mij D1mini. But when i connect the multiplexer it does not read the values. When i remove the multiplexer and connect my Potmeter to the analog pin everything works alright… I tryed to replace the multiplexer with a new one but same problem. i also checked my wiring and its all how it should be… can someone help me?
#define BLYNK_TEMPLATE_ID "TMPL000000"
#define BLYNK_DEVICE_NAME "NAME"
//#define BLYNK_DEBUG
#define APP_DEBUG
// Uncomment your board, or configure a custom board in Settings.h
//#define USE_SPARKFUN_BLYNK_BOARD
//#define USE_NODE_MCU_BOARD
//#define USE_WITTY_CLOUD_BOARD
#include "BlynkEdgent.h"
/* 16 channel Analog Multiplexer */
#define S0 D3 /* Assign Multiplexer pin S0 connect to pin D0 of NodeMCU */
#define S1 D4 /* Assign Multiplexer pin S1 connect to pin D1 of NodeMCU */
#define S2 D5 /* Assign Multiplexer pin S2 connect to pin D2 of NodeMCU */
#define S3 D6 /* Assign Multiplexer pin S3 connect to pin D3 of NodeMCU */
#define SIG A0 /* Assign SIG pin as Analog output for all 16 channels of Multiplexer to pin A0 of NodeMCU */
int decimal = 2; // Decimal places of the sensor value outputs
int sensor0; /* Assign the name "sensor0" as analog output value from Channel C0 */
int sensor1; /* Assign the name "sensor1" as analog output value from Channel C1 */
int sensor2; /* Assign the name "sensor2" as analog output value from Channel C2 */
int sensor3; /* Assign the name "sensor3" as analog output value from Channel C3 */
int sensor4; /* Assign the name "sensor4" as analog output value from Channel C4 */
int sensor5; /* Assign the name "sensor5" as analog output value from Channel C5 */
int sensor6; /* Assign the name "sensor6" as analog output value from Channel C6 */
int sensor7; /* Assign the name "sensor7" as analog output value from Channel C7 */
int sensor8; /* Assign the name "sensor8" as analog output value from Channel C8 */
int sensor9; /* Assign the name "sensor9" as analog output value from Channel C9 */
int sensor10; /* Assign the name "sensor10" as analog output value from Channel C10 */
int sensor11; /* Assign the name "sensor11" as analog output value from Channel C11 */
int sensor12; /* Assign the name "sensor12" as analog output value from Channel C12 */
int sensor13; /* Assign the name "sensor13" as analog output value from Channel C13 */
int sensor14; /* Assign the name "sensor14" as analog output value from Channel C14 */
int sensor15; /* Assign the name "sensor15" as analog output value from Channel C15 */
delay(100);
pinMode(S0,OUTPUT); /* Define digital signal pin as output to the Multiplexer pin SO */
pinMode(S1,OUTPUT); /* Define digital signal pin as output to the Multiplexer pin S1 */
pinMode(S2,OUTPUT); /* Define digital signal pin as output to the Multiplexer pin S2 */
pinMode(S3,OUTPUT); /* Define digital signal pin as output to the Multiplexer pin S3 */
pinMode(SIG, INPUT); /* Define analog signal pin as input or receiver from the Multiplexer pin SIG */
pinMode(D8, OUTPUT);
BlynkEdgent.begin();
void moistureSend() {
// Channel 0 (C0 pin - binary output 0,0,0,0)
digitalWrite(S0,LOW); digitalWrite(S1,LOW); digitalWrite(S2,LOW); digitalWrite(S3,LOW);
sensor0 = analogRead(SIG);
delay(100);
// Channel 1 (C1 pin - binary output 1,0,0,0)
digitalWrite(S0,HIGH); digitalWrite(S1,LOW); digitalWrite(S2,LOW); digitalWrite(S3,LOW);
sensor1 = analogRead(SIG);
delay(100);
// Channel 2 (C2 pin - binary output 0,1,0,0)
digitalWrite(S0,LOW); digitalWrite(S1,HIGH); digitalWrite(S2,LOW); digitalWrite(S3,LOW);
sensor2 = analogRead(SIG);
// Channel 3 (C3 pin - binary output 1,1,0,0)
digitalWrite(S0,HIGH); digitalWrite(S1,HIGH); digitalWrite(S2,LOW); digitalWrite(S3,LOW);
sensor3 = analogRead(SIG);
// Channel 4 (C4 pin - binary output 0,0,1,0)
digitalWrite(S0,LOW); digitalWrite(S1,LOW); digitalWrite(S2,HIGH); digitalWrite(S3,LOW);
sensor4 = analogRead(SIG);
// Channel 5 (C5 pin - binary output 1,0,1,0)
digitalWrite(S0,HIGH); digitalWrite(S1,LOW); digitalWrite(S2,HIGH); digitalWrite(S3,LOW);
sensor5 = analogRead(SIG);
// Channel 6 (C6 pin - binary output 0,1,1,0)
digitalWrite(S0,LOW); digitalWrite(S1,HIGH); digitalWrite(S2,HIGH); digitalWrite(S3,LOW);
sensor6 = analogRead(SIG);
// Channel 7 (C7 pin - binary output 1,1,1,0)
digitalWrite(S0,HIGH); digitalWrite(S1,HIGH); digitalWrite(S2,HIGH); digitalWrite(S3,LOW);
sensor7 = analogRead(SIG);
// Channel 8 (C8 pin - binary output 0,0,0,1)
digitalWrite(S0,LOW); digitalWrite(S1,LOW); digitalWrite(S2,LOW); digitalWrite(S3,HIGH);
sensor8 = analogRead(SIG);
// Channel 9 (C9 pin - binary output 1,0,0,1)
digitalWrite(S0,HIGH); digitalWrite(S1,LOW); digitalWrite(S2,LOW); digitalWrite(S3,HIGH);
sensor9 = analogRead(SIG);
// Channel 10 (C10 pin - binary output 0,1,0,1)
digitalWrite(S0,LOW); digitalWrite(S1,HIGH); digitalWrite(S2,LOW); digitalWrite(S3,HIGH);
sensor10 = analogRead(SIG);
// Channel 11 (C11 pin - binary output 1,1,0,1)
digitalWrite(S0,HIGH); digitalWrite(S1,HIGH); digitalWrite(S2,LOW); digitalWrite(S3,HIGH);
sensor11 = analogRead(SIG);
// Channel 12 (C12 pin - binary output 0,0,1,1)
digitalWrite(S0,LOW); digitalWrite(S1,LOW); digitalWrite(S2,HIGH); digitalWrite(S3,HIGH);
sensor12 = analogRead(SIG);
// Channel 13 (C13 pin - binary output 1,0,1,1)
digitalWrite(S0,HIGH); digitalWrite(S1,LOW); digitalWrite(S2,HIGH); digitalWrite(S3,HIGH);
sensor13 = analogRead(SIG);
// Channel 14 (C14 pin - binary output 0,1,1,1)
digitalWrite(S0,LOW); digitalWrite(S1,HIGH); digitalWrite(S2,HIGH); digitalWrite(S3,HIGH);
sensor14 = analogRead(SIG);
// Channel 15 (C15 pin - binary output 1,1,1,1)
digitalWrite(S0,HIGH); digitalWrite(S1,HIGH); digitalWrite(S2,HIGH); digitalWrite(S3,HIGH);
sensor15 = analogRead(SIG);
Serial.print("Sensor 0 : ");Serial.println(sensor0); /* state value for sensor 0 */
Serial.print("Sensor 1 : ");Serial.println(sensor1); /* state value for sensor 1 */
Serial.print("Sensor 2 : ");Serial.println(sensor2); /* state value for sensor 2 */
Serial.print("Sensor 3 : ");Serial.println(sensor3); /* state value for sensor 3 */
Serial.print("Sensor 4 : ");Serial.println(sensor4); /* state value for sensor 4 */
Serial.print("Sensor 5 : ");Serial.println(sensor5); /* state value for sensor 5 */
Serial.print("Sensor 6 : ");Serial.println(sensor6); /* state value for sensor 6 */
Serial.print("Sensor 7 : ");Serial.println(sensor7); /* state value for sensor 7 */
Serial.print("Sensor 8 : ");Serial.println(sensor8); /* state value for sensor 8 */
Blynk.virtualWrite(V0, sensor0);
Blynk.virtualWrite(V1, sensor1);
Blynk.virtualWrite(V2, sensor2);
Blynk.virtualWrite(V3, sensor3);
Blynk.virtualWrite(V4, sensor4);
Blynk.virtualWrite(V5, sensor5);
Blynk.virtualWrite(V6, sensor6);
Blynk.virtualWrite(V7, sensor7);
BlynkEdgent.run();
if (Blynk.connected() == true){
moistureSend();
digitalWrite(D8, LOW);
else {
digitalWrite(D8, HIGH);
