Hello again,
I’m struggling to see my mistake. Basically using a temp sensor and slider to create a low setpoint. When my project runs, I’m always getting a low alarm. Despite the temp coming back into the normal range I cannot loose my alarm.
I really can’t see what I’m doing wrong.
Would really appreciate another eye.
Thanks Joe
// First we include the libraries
#include <OneWire.h>
// Data wire is plugged into pin 2 on the Arduino
#define ONE_WIRE_BUS 2 // on pin 4 of wemos d1 using virtual pin 0 for readout on app
// Setup a oneWire instance to communicate with any OneWire devices
// (not just Maxim/Dallas temperature ICs)
// Pass our oneWire reference to Dallas Temperature.
// Widget colors for alerts
#define ALERT_COLOR_OK "#23C48E" // Green
#define ALERT_COLOR_LOW "#5F7CD8" // Dark Blue
#define ALERT_COLOR_HIGH "#D3435C" // Red
// Alert messages
char alertMessageLow[] = "Temperature is LOW!";
char alertMessageHigh[] = "Temperature is HIGH!";
int alertTempLow, alertTempHigh;
boolean lowAlertOn = false;
boolean highAlertOn = false;
// Hysteresis in degrees for alerts
#define ALERT_HYSTERESIS 1
char auth[] = "";
char ssid[] = "";
char pass[] = "";
Blynk.begin(auth, ssid, pass, IPAddress(192,168,1,60), 8080);
sensors.begin();
timer.setInterval(1000L, TempSensorRead);
float currentTemp = 0;
void TempSensorRead(){
Blynk.virtualWrite(V0, sensors.getTempCByIndex(0));
// Low temperature alerts
if ((currentTemp <= alertTempLow) && !lowAlertOn) {
Blynk.setProperty(V0, "color", ALERT_COLOR_LOW);
Blynk.notify(alertMessageLow);
lowAlertOn = true;
else if (lowAlertOn && (currentTemp > alertTempLow + ALERT_HYSTERESIS)) {
Blynk.setProperty(V0, "color", ALERT_COLOR_OK);
lowAlertOn = false;
BLYNK_WRITE(V1) {
alertTempLow = param.asInt();
Blynk.virtualWrite(V2, alertTempLow);
I think it’s your currentTemp
value.
You’re setting it to zero (I’d move that line of code up so that it’s with your other declarations) then it never changes.
I’d say that this:
should be more like this:
currentTemp = sensors.getTempCByIndex(0);
Blynk.virtualWrite(V0, currentTemp);
Thanks Peter - what would I be doing with float currentTemp = 0;
Would I just do float currentTemp;
The float currentTemp = 0;
is fine, it’s just that it’s “floating” in the middle of your sketch.
You have your global variables defined up here:
so just move it up with them, so it doesn’t feel lonely and you can easily find it when you want it.
My personal taste is not to have multiple declarations on each line, and to add some comments to help later debugging and code changes, so my declarations would look something like this:
int alertTempLow; // Temperature at/below which alerts will be sent
int alertTempHigh; // Temperature above which alerts will be sent
boolean lowAlertOn = false; // flag to show that low alert message has been sent via Blynk
boolean highAlertOn = false; // flag to show that highalert message has been sent via Blynk
float currentTemp = 0; // Current temp reading (if we ever assign it a value :-)
#define ALERT_HYSTERESIS 1 // Hysteresis in degrees for alerts
A quick tip about debugging…
Using serial print statements is a great way to see snapshots of variable values, and to see which branches of for…else statements are being executed.
This is your original code, with some serial print statements added…
Serial.println("We're in branch 1 of the if statement");
Serial.print("currentTemp = ");
Serial.println(currentTemp);
Serial.print("alertTempLow = ");
Serial.println(alertTempLow);
Serial.print("lowAlertOn = ");
Serial.println(lowAlertOn);
lowAlertOn = true;
Serial.println("We're in branch 2 of the if statement");
Serial.print("ALERT_HYSTERESIS = ");
Serial.println(ALERT_HYSTERESIS);
lowAlertOn = false;
I think it would have shown that ```currentTemp``` is always zero.
Thanks again Peter. I will give it a go.
Peter your a star - you’ve solved it for me.
Final code for anyone else to use:
// Alert messages
char auth[] = "";
char ssid[] = "";
char pass[] = "";
sensors.begin();
lowAlertOn = true;
lowAlertOn = false;
BLYNK_WRITE(V1) {
