Who has already tested the AHT10 or 20 temperature sensor?
I have a hardware reset with blynk.
It seems that the library code has a blocking loop.
I will investigate more.
Tell me if you have any information.
Which AHTX0 library are you using, and which AHTX0 hardware?
AHT10 but it’s the same than AHT20
I try Adafruit AHTX0 library and SparkFun
Same issue with blynk, works fine with the basic example provided.
Exception (28):
epc1=0x402054c2 epc2=0x00000000 epc3=0x00000000 excvaddr=0x0000000c depc=0x00000000
>>>stack>>>
ctx: cont
sp: 3ffffcf0 end: 3fffffc0 offset: 0190
You don’t have the new beta version of the Blynk library installed do you?
Pete…
I have the new Blynk library since yesterday , but it was the same issue before
I will try without writing to Nextion serial port , I have a doubt.
I had lots of problems when I installed the new library alongside 0.6.1, so I now have the new library on a machine of its own.
You could also try swapping around the order of the #include commands to see if that helps.
thank you Peter,
I think my mistake was to copy and paste the example code, I rewrote my code from scratch, everything works now !
I must have been asleep
#include <Adafruit_AHTX0.h>
Adafruit_AHTX0 aht;
#define TEMPERATURE_PRECISION 10 // Lower resolution
timer.setInterval(10010L, TempUpdate);
void TempUpdate() {
sensors_event_t humidity, temp;
aht.getEvent(&humidity, &temp);// populate temp and humidity objects with fresh data
temperature = temp.temperature + Calibration;
temperature = rounded(temperature);
Humidity = humidity.relative_humidity;
///////////////////////////////////// temp /////////////////////////////////////
String T_Int = String(temperature).substring(0, 2);
WriteStr( "home.T_Int.txt", T_Int);
Blynk.virtualWrite(V3, temperature);
Bridge1.virtualWrite(V19, temperature);//MCU55
String D_Int = String(temperature).substring(2, 4); //décimal
WriteStr( "home.D_Int.txt", D_Int);//Send to Nextion
int gauge = map(temperature, 0, 40, 0, 100);
WriteNum( "home.j1.val", gauge);//Send to Nextion
///////////////////////////////////// Hum /////////////////////////////////////
String H_Int = String(humidity.relative_humidity).substring(0, 2);;
WriteStr( "home.H_Int.txt", H_Int);//Send to Nextion
Blynk.virtualWrite(V8, H_Int);
I have the same
You have to learn blynk structure before, because your sketch will never works as is
I am using nodeMCU too, so you can use my sketch
don’t use wire.h , and replace my virtual pins as you want
replace
#include <Thinary_AHT10.h>
AHT10Class AHT10;
by
Adafruit_AHTX0 aht;
You have no timer in your code, nor in your loop
As I said , you have to learn blynk before trying to get data from sensor
We are here to help, but we have no time to write code for users .
Try to learn Blynk before
Good idea , tell us if you need help
