This is really odd.
After upgrading to .19.0 on local server everything works fine. I can create new projects all old projects work fine but when I run blynk admin i can see the user name. When I click on the username it show no info for that user.
There is only one user on the system and it is me.
So when I click on the only user that is there it goes to edit user page but everything is blank. empty fields. like so.
Edit user ""
Name
Pass
LastModifiedTs
Energy
AppName
Region
Profile DashBoards
DashTokens
Just want to reiterate that everything works fine. I have not tried to add energy or manually enter info here because I am afraid of losing everything.
I went ahead and upgraded to 19.1
Still no luck.
When I go to the server and open up the user file all the details are in there.
It is just that the blynk administration routine in edit mode will not see anything.
@Dmitriy can you tell us if the password is stored in has format in the user file? Maybe @dennymoney can send me/you the user file and we can check with another installation of local blynk server if the file is OK.
I’d love to test something for you, if you are willing to send your user file, but I’m not sure about the passwords in side them. I hope they are stored using irreversible encryption though …
