Hi! I’m trying to setup my ESP8266 with 3 DHT22s, 3 Soil Moisture Sensors, And 3 Light Sensors. The light sensors and the moisture sensors need more than the 1 analog input on the ESP8266. I have two ADS1115s because I read that they can be wired together. I’ve tried looking at other topic similar to mine but I’m still drawing a blank. I’m quite new to this! This is for a school project.
I have the code for the 3 DHT22 sensors working
#include <DHT.h>
//My auth token to connect to the Blynk app.
char auth[] = "***********";
//My Wifi SSID and password.
char ssid[] = "**********";
char pass[] = "************";
// These 3 define what Digital pin we're connected to. (NodeMCU Esp8266 was a weird pin layout)
#define DHTPIN 14
#define DHTPIN2 12
#define DHTPIN3 13
//Defines which DHT type I have.
#define DHTTYPE DHT22 // DHT 22, AM2302, AM2321
DHT dht(DHTPIN, DHTTYPE);
DHT dht2(DHTPIN2, DHTTYPE);
DHT dht3(DHTPIN3, DHTTYPE);
// This function sends Arduino's up time every second to Virtual Pins.
void sendSensor()
float h = dht.readHumidity();
float h2 = dht2.readHumidity();
float t2 = dht2.readTemperature();
float h3 = dht3.readHumidity();
float t3 = dht3.readTemperature();
if (isnan(h) || isnan(t) || isnan(h2) || isnan(t2) || isnan(h3) || isnan(t3)) {
return;
Blynk.virtualWrite(V5, h);
Blynk.virtualWrite(V6, t);
Blynk.virtualWrite(V1, h2);
Blynk.virtualWrite(V2, t2);
Blynk.virtualWrite(V3, h3);
Blynk.virtualWrite(V4, t3);
dht.begin();
But I’m still clueless as to how to configure the ADS1115 code. What is the gain for?
#include <Wire.h>
#include <Adafruit_ADS1015.h>
// Adafruit_ADS1115 ads; /* Use this for the 16-bit version */
Adafruit_ADS1015 ads; /* Use thi for the 12-bit version */
void setup(void)
Serial.println("Hello!");
Serial.println("Getting single-ended readings from AIN0..3");
Serial.println("ADC Range: +/- 6.144V (1 bit = 3mV/ADS1015, 0.1875mV/ADS1115)");
// The ADC input range (or gain) can be changed via the following
// functions, but be careful never to exceed VDD +0.3V max, or to
// exceed the upper and lower limits if you adjust the input range!
// Setting these values incorrectly may destroy your ADC!
// ADS1015 ADS1115
// ads.setGain(GAIN_TWOTHIRDS); // 2/3x gain +/- 6.144V 1 bit = 3mV 0.1875mV (default)
// ads.setGain(GAIN_ONE); // 1x gain +/- 4.096V 1 bit = 2mV 0.125mV
// ads.setGain(GAIN_TWO); // 2x gain +/- 2.048V 1 bit = 1mV 0.0625mV
// ads.setGain(GAIN_FOUR); // 4x gain +/- 1.024V 1 bit = 0.5mV 0.03125mV
// ads.setGain(GAIN_EIGHT); // 8x gain +/- 0.512V 1 bit = 0.25mV 0.015625mV
// ads.setGain(GAIN_SIXTEEN); // 16x gain +/- 0.256V 1 bit = 0.125mV 0.0078125mV
ads.begin();
void loop(void)
int16_t adc0, adc1, adc2, adc3;
adc0 = ads.readADC_SingleEnded(0);
adc1 = ads.readADC_SingleEnded(1);
adc2 = ads.readADC_SingleEnded(2);
adc3 = ads.readADC_SingleEnded(3);
Serial.print("AIN0: "); Serial.println(adc0);
Serial.print("AIN1: "); Serial.println(adc1);
Serial.print("AIN2: "); Serial.println(adc2);
Serial.print("AIN3: "); Serial.println(adc3);
Serial.println(" ");
Thanks in advance!
