Adruino Uno,Esp8266 esp-01 Module & Ds3231 Issue
Hello
Im having an issue with the esp8266 esp-01 module and the ds3231 working together using an Arduino Uno.
When I upload the code below something is causing major issues like disconnects and it wont send notification, date & time to the blynk app. I have tested by removing the RTC libraries, functions and timers and only left the send notification and it works perfect, sends the notification. Can someone look at my sketch and see right off what my problem might be? Or what ds3231 Library and sketch that will work with this setup
    Follow us:                  http://www.fb.com/blynkapp
                                http://twitter.com/blynk_app
  WARNING!
    It's very tricky to get it working. Please read this article:
    http://help.blynk.cc/hardware-and-libraries/arduino/esp8266-with-at-firmware
  Simple push notification example
  App project setup:
    Push widget
  Connect a button to pin 2 and GND...
  Pressing this button will also push a message! ;)
#include <ESP8266_Lib.h>
#include <RTClib.h>
#include <Wire.h>
// the timer object
RTC_DS3231 rtc;
char auth[] = "*************************";
char ssid[] = "***************";
char pass[] = "*************";
//#define EspSerial Serial1
// Your ESP8266 baud rate:
#define ESP8266_BAUD 9600
ESP8266 wifi(&EspSerial);
void sendTime()
  DateTime now = rtc.now();
  char dateBuffer[12];
  sprintf(dateBuffer, "%02u:%02u ", now.hour(), now.minute());
  Serial.println(dateBuffer);
  Blynk.virtualWrite(V10, dateBuffer);
  // Set ESP8266 baud rate
  //Blynk.begin(auth, wifi, ssid, pass, "blynk-cloud.com", 8442);
  //Blynk.begin(auth, wifi, ssid, pass, IPAddress(192,168,1,100), 8442);
Blynk.notify("Chicken Coop Online");
timer.setInterval(1000L, sendTime );
Issue Solved by removing Blynk.notify(“Chicken Coop Online”); from void setup
