Tonight project was trying to add a second device to a template.
I have one ESP 32 giving temperature info from a sensor on a virtual pin. I tried adding a second ESP32 to provide info from an analog pot on another virtual pin (datastreams)
In the mobile app I can get temp info be no pot voltage or pot voltage but no temp info.
Can you get info from two devices and display them on the same page?
This example shows how to fetch data using WebHook GET method
App project setup:
WebHook widget on V0, method: GET, url: /pin/
#define BLYNK_TEMPLATE_ID "TMPLxxxxxx"
#define BLYNK_DEVICE_NAME "Device"
#define BLYNK_AUTH_TOKEN "YourAuthToken"
// Allow for receiving messages up to 512 bytes long
//#define BLYNK_MAX_READBYTES 512
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
char pass[] = "YourPassword";
BLYNK_WRITE(V0)
Serial.println("WebHook data:");
Serial.println(param.asStr());
//Blynk.begin(auth, ssid, pass, "blynk.cloud", 80);
Blynk.virtualWrite(V0, "https://raw.githubusercontent.com/blynkkk/blynk-library/master/extras/logo.txt");
// You can perform HTTPS requests even if your hardware alone can't handle SSL
// Blynk can also fetch much bigger messages,
// if hardware has enough RAM (set BLYNK_MAX_READBYTES to 4096)
//Blynk.virtualWrite(V0, "https://api.sunrise-sunset.org/json?lat=50.4495484&lng=30.5253873&date=2016-10-01");
