Add Value to Notification
I am trying to send a light value from analog sensor to be displayed with my iOS notification. I try this code but get errors. I cant get it to work, only the normal notification without the lightVal.
I would greatly appreciate the help.
Thank you
 if (lightVal > 600 ) {
    led1.setColor(BLYNK_GREEN);
    led1.on();
    if ( lightVal > 300 && lightflag == true ) {  /// Bright lights? Say so
      lightflag = false;
      Blynk.notify("Current Lumens" + lightVal);
      terminal.println("Lights are on");
      Serial.println("Lights on");
      Serial.println("-------------");
  else  {
    lightflag = true;
What errors do you get? Does this work in terminal? ("Current Lumens" + lightVal)
I’m guessing that the string isn’t formatted correctly.
You have to change to
Blynk.notify("Current Lumens" + String(lightVal));
or for 1 decimal place
Blynk.notify("Current Lumens" + String(lightVal, 1));
Another point is in
lightVal > 300 is redundant as it is always true : lightVal > 600
So that if as the same as
if (lightflag == true )
Thank you for your input, your first code suggestion worked great.
