Edit: I am using Blynk on my IPhone 6S.
I have the nRF8001 breakout board from ADAFRUIT. I can’t get the Blynk app to see the ble device. Here’s my setup:
Atmega328P-AU on a custom PCB, including the nRF8001 on pins 10, 2, & 7
When I run the example sketch by adafruit, “echo demo”, and include the line:
BTLEserial.setDeviceName(“Test”); /* 7 characters max! */
Then, in the Blynk app, when I add the BLE device and try to connect, “Test” shows up.
But when I run the example sketch from Blynk, and then goto connect, nothing shows up to connect to. I have deleted the libraries, reinstalled them using the library manager, but no change. I tried commenting out the include spi.h line like I read about in one post.
Here are the 2 sketches exactly as described. The echo test one will cause the BLE to show up (it also is visible as "Test"Adafruit’s BLE app). And the example sketch from Blynk called “Adafruit_Bluefruit LE” It causes nothing to show up when trying to connect. (It causes nothing to show with Adafruit’s BLE ap). I’ve also tried another example sketch from the blink library called nRF8001 with the same results. I’ve tried resetting my authToken a couple times and emailing it.
BELOW ARE THE 2 SKETCHES
The echo sketch from adafruit that causes the nRF8001 to show up:
This is an example for our nRF8001 Bluetooth Low Energy Breakout
Pick one up today in the adafruit shop!
------> http://www.adafruit.com/products/1697
Adafruit invests time and resources providing this open source code,
please support Adafruit and open-source hardware by purchasing
products from Adafruit!
Written by Kevin Townsend/KTOWN for Adafruit Industries.
MIT license, check LICENSE for more information
All text above, and the splash screen below must be included in any redistribution
// This version uses the internal data queing so you can treat it like Serial (kinda)!
#include "Adafruit_BLE_UART.h"
// Connect CLK/MISO/MOSI to hardware SPI
// e.g. On UNO & compatible: CLK = 13, MISO = 12, MOSI = 11
#define ADAFRUITBLE_REQ 10
#define ADAFRUITBLE_RDY 2 // This should be an interrupt pin, on Uno thats #2 or #3
#define ADAFRUITBLE_RST 7
Adafruit_BLE_UART BTLEserial = Adafruit_BLE_UART(ADAFRUITBLE_REQ, ADAFRUITBLE_RDY, ADAFRUITBLE_RST);
Configure the Arduino and start advertising with the radio
void setup(void)
while(!Serial); // Leonardo/Micro should wait for serial init
Serial.println(F("Adafruit Bluefruit Low Energy nRF8001 Print echo demo"));
BTLEserial.setDeviceName("Test"); /* 7 characters max! */
BTLEserial.begin();
Constantly checks for new events on the nRF8001
aci_evt_opcode_t laststatus = ACI_EVT_DISCONNECTED;
// Tell the nRF8001 to do whatever it should be working on.
BTLEserial.pollACI();
// Ask what is our current status
aci_evt_opcode_t status = BTLEserial.getState();
// If the status changed....
if (status != laststatus) {
// print it out!
if (status == ACI_EVT_DEVICE_STARTED) {
Serial.println(F("* Advertising started"));
if (status == ACI_EVT_CONNECTED) {
Serial.println(F("* Connected!"));
if (status == ACI_EVT_DISCONNECTED) {
Serial.println(F("* Disconnected or advertising timed out"));
// OK set the last status change to this one
laststatus = status;
// Lets see if there's any data for us!
if (BTLEserial.available()) {
Serial.print("* "); Serial.print(BTLEserial.available()); Serial.println(F(" bytes available from BTLE"));
// OK while we still have something to read, get a character and print it out
while (BTLEserial.available()) {
char c = BTLEserial.read();
Serial.print(c);
// Next up, see if we have any data to get from the Serial console
if (Serial.available()) {
// Read a line from Serial
Serial.setTimeout(100); // 100 millisecond timeout
String s = Serial.readString();
// We need to convert the line to bytes, no more than 20 at this time
uint8_t sendbuffer[20];
s.getBytes(sendbuffer, 20);
char sendbuffersize = min(20, s.length());
Serial.print(F("\n* Sending -> \"")); Serial.print((char *)sendbuffer); Serial.println("\"");
// write the data
BTLEserial.write(sendbuffer, sendbuffersize);
This sample code from Blynk causes the BLE device to not show up:
* Downloads, docs, tutorials: http://www.blynk.cc
* Blynk community: http://community.blynk.cc
* Social networks: http://www.fb.com/blynkapp
* http://twitter.com/blynk_app
* This example shows how to use Adafruit Bluefruit LE nRF8001 breakout
* to connect your project to Blynk.
* Note: This requires BLEPeripheral library
* from http://librarymanager
* or https://github.com/sandeepmistry/arduino-BLEPeripheral
* NOTE: BLE support is in beta!
//#define BLYNK_DEBUG
#include <BLEPeripheral.h>
#include "BLESerial.h"
char auth[] = "443a7dae08294ea0a4314d3d2492a181";
// Define pins (varies per shield/board)
#define BLE_REQ 10
#define BLE_RDY 2
#define BLE_RST 7
// Create ble serial instance, see pinouts above
BLESerial SerialBLE(BLE_REQ, BLE_RDY, BLE_RST);
SerialBLE.setLocalName("Blynk");
SerialBLE.setDeviceName("Blynk");
SerialBLE.setAppearance(0x0080);
SerialBLE.begin();
Blynk.begin(auth, SerialBLE);
SerialBLE.poll();
if (SerialBLE) { // If BLE is connected...
(There are 2 other tabs on the example sketch, but I changed nothing on them)
