I’m completely new to this IoT world but i deeply wish to include this in my project .
this code is a basic arduino program which reads pin A0 and serialprints the exact measure of load current . I would like to use arduino UNO + esp8266 e01 wifi shield + blynk (android)
ive checked blynk coder online , but found it tough . please be kind enough to help me in the coding so that this project could use IoT !
// include the library code:
#include <LiquidCrystal.h> //library for LCD
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(8, 9, 10, 11, 12, 13);
//Measuring Current Using ACS712
int pinOut = 7;
const int analogchannel = 0; //Connect current sensor with A0 of Arduino
int sensitivity = 66; // use 100 for 20A Module and 66 for 30A Module
float adcvalue= 0;
int offsetvoltage = 2500;
double Voltage = 0; //voltage measuring
double ecurrent = 0;// Current measuring
//baud rate
Serial.begin(9600);//baud rate at which arduino communicates with Laptop/PC
// set up the LCD's number of columns and rows:
lcd.begin(20, 4); //LCD order
// Print a message to the LCD.
lcd.setCursor(1,1);//Setting cursor on LCD
lcd.print("MICROCONTROLLERSLAB");//Prints on the LCD
lcd.setCursor(4,2);
lcd.print(".com");
delay(3000);//time delay for 3 sec
lcd.clear();//clearing the LCD display
lcd.display();//Turning on the display again
lcd.setCursor(1,0);//setting LCD cursor
lcd.print("Reading Values from");//prints on LCD
lcd.setCursor(1,1);
lcd.print("AC Current Sensor");
lcd.setCursor(5,2);
lcd.print("ACS 712");
delay(10000);//delay for 2 sec
void loop() //method to run the source code repeatedly
unsigned int temp=0;
float maxpoint = 0;
int i=0;
for(i=0;i<500;i++)
if(temp = analogRead(analogchannel),temp>maxpoint)
maxpoint = temp;
adcvalue = maxpoint;
Voltage = (adcvalue / 1024.0) * 5000; // Gets you mV
ecurrent = ((Voltage - offsetvoltage) / sensitivity);
ecurrent = ( ecurrent ) / ( sqrt(2) );
lcd.clear();//clears the display of LCD
delay(1000);//delay of 1 sec
lcd.display();
lcd.setCursor(1,0);
Serial.print("\t ecurrent = "); // shows the voltage measured
Serial.println(ecurrent,3);// the '3' after voltage allows you to display 3 digits after decimal point
lcd.setCursor(1,2);
lcd.print("ac Current = ");
lcd.setCursor(11,2);
lcd.print(ecurrent,3);
lcd.setCursor(16,2);
lcd.print("A"); //unit for the current to be measured
delay(2500); //delay of 2.5 sec
