To make a short answer long After a quick look at the available examples, it appears to be a simple dumb triac based dimmer - dumb as in the microcontroller can’t just send a PWM signal, but must rapidly pulse digital pins at the microsecond range. They do show an advanced example that uses TimerOne.h library (for ATmega168/328 - probably no good for ESP), but then you would have to test to see if that works alongside Blynk’s library without causing timing conflicts… I would suggest finding something else that just requires a PWM signal.
So in answer, no quick answer. But if you get it, test it as @Jamin suggests. Then someone might be able to assist in the Blynkification.
