why it show like this
coding
#define BLYNK_TEMPLATE_ID "TMPL6mqBMDzCJ"
#define BLYNK_TEMPLATE_NAME "Petpal Feeder Pro"
#define BLYNK_AUTH_TOKEN "WIswWuhxulyWC2AGizDMNe_SONZ2cbD5"
#include <Wire.h>
#include <RTClib.h>
#include <ESP32Servo.h>
#include <NewPing.h>
#include <WiFi.h>
#include <BlynkSimpleEsp32.h>
// Blynk Auth Token
char auth[] = "WIswWuhxulyWC2AGizDMNe_SONZ2cbD5"; // Replace with your Blynk Auth Token
// Your WiFi credentials
char ssid[] = "iPhone"; // Replace with your WiFi SSID
char pass[] = "yan12345678"; // Replace with your WiFi Password
// RTC
RTC_DS3231 rtc;
// Servo
Servo bowlServo;
Servo valveServo;
// Ultrasonic Sensor
#define TRIGGER_PIN 5
#define ECHO_PIN 17
#define MAX_DISTANCE 200
NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE);
// Blynk Virtual Pins for scheduling
#define VPIN_SCHEDULE_DAY V1
#define VPIN_SCHEDULE_HOUR V2
#define VPIN_SCHEDULE_MINUTE V3
// Schedule variables
int scheduleDay;
int scheduleHour;
int scheduleMinute;
// Flag to check if feeding is in progress
bool feedingInProgress = false;
delay(100);
// Initialize RTC
if (!rtc.begin()) {
Serial.println("Couldn't find RTC");
while (1);
Serial.println("RTC initialized successfully");
// Initialize Servos
bowlServo.attach(18);
valveServo.attach(19);
Serial.println("Servos attached");
// Initialize WiFi
Serial.print("Connecting to WiFi: ");
Serial.println(ssid);
WiFi.begin(ssid, pass);
// Wait for connection
delay(500);
Serial.print(".");
Serial.println("\nWiFi connected");
// Initialize Blynk
Serial.println("Connecting to Blynk...");
// Wait for Blynk connection
while (!Blynk.connected()) {
Serial.println("Attempting to connect to Blynk...");
Serial.println("Connected to Blynk");
// Synchronize time
rtc.adjust(DateTime(F(__DATE__), F(__TIME__))); // Set RTC to compile time
// rtc.adjust(DateTime(2024, 5, 27, 12, 0, 0)); // Or set manually
if (Blynk.connected()) {
Serial.println("Blynk disconnected, attempting to reconnect...");
Blynk.connect(); // Attempt to reconnect
DateTime now = rtc.now();
if (now.dayOfTheWeek() == scheduleDay && now.hour() == scheduleHour && now.minute() == scheduleMinute && !feedingInProgress) {
startFeedingCycle();
if (feedingInProgress) {
checkFeedingStatus();
void startFeedingCycle() {
feedingInProgress = true;
// Move bowl out
bowlServo.write(90); // Adjust angle as necessary
delay(1000); // Allow time for bowl to move
// Open valve
valveServo.write(90); // Adjust angle as necessary
delay(10000); // Keep valve open for 10 seconds
// Close valve
valveServo.write(0); // Adjust angle as necessary
// Start timer to retract bowl after 10 minutes
delay(600000); // 10 minutes
bowlServo.write(0); // Retract bowl
void checkFeedingStatus() {
int distance = sonar.ping_cm();
if (distance > 0 && distance < 20) {
Serial.println("Food level low!");
// Send notification via Blynk Event
Blynk.logEvent("low_food_level", "Food level is below 20 cm!");
BLYNK_WRITE(VPIN_SCHEDULE_DAY) {
scheduleDay = param.asInt();
BLYNK_WRITE(VPIN_SCHEDULE_HOUR) {
scheduleHour = param.asInt();
BLYNK_WRITE(VPIN_SCHEDULE_MINUTE) {
scheduleMinute = param.asInt();
