According to Particle code sample
#define BLYNK_PRINT Serial // Set serial output for debug prints
//#define BLYNK_DEBUG // Uncomment this to see detailed prints
#include <blynk.h>
// Attach a Button widget (mode: Switch) to the Digital pin 7 - and control the built-in blue led.
// Attach a Graph widget to Analog pin 1
// Attach a Gauge widget to Analog pin 2
delay(5000); // Allow board to settle
Blynk.begin(auth);
// Attach a Button widget (mode: Push) to the Virtual pin 1 - and send sweet tweets!
BLYNK_WRITE(V1) {
if (param.asInt() == 1) { // On button down...
// Tweeting!
// Note:
// We allow 1 tweet per minute for now.
// Twitter doesn't allow identical subsequent messages.
Blynk.tweet("My Particle project is tweeting using @blynk_app and it’s awesome!\n @Particle #IoT #blynk");
// Pushing notification to the app!
// Note:
// We allow 1 notification per minute for now.
Blynk.notify("You pressed the button and I know it ;)");
// Attach a ZeRGBa widget (mode: Merge) to the Virtual pin 2 - and control the built-in RGB led!
BLYNK_WRITE(V2) {
int r = param[0].asInt();
int g = param[1].asInt();
int b = param[2].asInt();
if (r > 0 || g > 0 || b > 0) {
RGB.control(true);
RGB.color(r, g, b);
RGB.control(false);
Are these three lines necessary?
I know they are for debugging. But if I don’t need them, are they necessary to make Particle work with Blynk? Thanks
