hi blynkers
how can i make a project with 433mhz moduls (RC/TR) and raspberry pi that is controles by blynk?
i saw one with esp
regards
jer
Jer,
Try “Lowpowerlabs.com” using the Motieno boards. They operate at 433Mhz. The Raspberry Pi server has an Image that loads and puts you up and running in no time. As long as you get the Network ID’d, the Gateway # on both the server and the nodes the same and your encrypted password consistent the system has great range. It has a simple HTML UI for beginners to control anything.
Goodluck
thank you for your reply but i know how to handle 433mhz devices with ny own HTML .
in this projcet i want to use blynk and my raspberry pi .
i hope there is a blynk lib for that or some api code to put on the raspberry
@faljeremy as far as I know there aren’t any Blynk RF libraries as such but you are probably aware that there are RF libraries for the Pi. So Blynk virtually pushes the RF button wired up to your Pi.
I don’t know the first thing about java so I can’t give any further assistance but yes you can do RF with a Blynk connected Pi.
