Hi Blynkers!
Today I wanted to share with you this little “toy” made using a 3D Printer working together with Blynk.
It’s base on Adafruit “3D Printed LED-Animation BMO” you can find here.
I have added several functions and sensors so I can see the temperature (with a Ds18b20 temperature sensor) and I can notice if somebody is at home while I’m on vacation for instance (using a PIR sensor).
This is how it looks like:
As you can see on top the PIR and the Ds18b20 sensor.
I have been “playing” with several widgets (Menu, Table, Notification and Real-Time clock)
With the Menu widget I can control the information showed at the Matrix. At the moment it has 4 options, Temperature (ºC), Facial expressions, Intrusion and “Secretive” intrusion.
The difference between Intrusion and “Secretive” intrusion is really small, at Intrusion, the display changes when somebody is being detected. At “secretive” intrusion there’re 4 leds On and it doesn’t change while detecting.
At the same time, a Table is filled adding the time in every movement detected (in the near future I wil add the complete date also)
The video is here:
The code is here:
#include <ArduinoOTA.h> // for local OTA updates
#include <SimpleTimer.h> //Blynk
//********************* display DETAILS ******************************************
#include <Wire.h>
#include "Adafruit_LEDBackpack.h"
#include "Adafruit_GFX.h"
Adafruit_8x8matrix matrix = Adafruit_8x8matrix();
//********************* ds18b20 DETAILS ******************************************
#include <OneWire.h> //ds18b20 Temp
#include <DallasTemperature.h> //ds18b20 Temp
#define Pin D7// pin DATA ds18b20
OneWire oneWire(Pin); // OneWire PIN DATA
DallasTemperature sensors(&oneWire); // DallasTemperature library
float temp;
//********************* CLOCK DETAILS *********************************************
#include <WidgetRTC.h>//Blynk
WidgetRTC rtc;
BLYNK_ATTACH_WIDGET(rtc, V0);// VIRTUAL PIN FOR WIDGET
//********************* SECTION TO COMPLETE WITH YOUR DETAILS *************
// Get Auth Token in the Blynk App.
char auth[] = "blablablablablablablabla"; // Go to the Project Settings (nut icon).
char cloudserver[16] = "blynk-cloud.com";
char localserver[16] = "xxx.xxx.xxx.xxx"; // Enter your IP details for the local server 192,168,1,12
char ssid[] = "xxxxxxxx"; // Your WiFi credentials.
char pass[] = "xxxxxxxxxxxxxxxxx"; // Set password to "" for open networks.
char OTAhost[] = "WiFi4OTA1"; // Optional
bool isFirstConnect = true;
int sensorPin=2; // PIR at pin D4
int modotemperatura;
int modocaritas;
int modoalarma;
int modoalarmasigilosa;
int sequence=0;
int alarmaactiva=0;
int alarmasilenciosa=0;
int alarmacamuflada=0;
int val; // Para leer valor del sensorPin
int rowIndex = 0;// table
int camuflada=0;
BLYNK_CONNECTED() {
if (isFirstConnect) {
Blynk.syncAll();
Blynk.notify("Arrancando!!!");
isFirstConnect = false;
static const uint8_t PROGMEM
number_0[] = {B00000001, B11101110, B10101010, B10101010, B10101010, B10101010, B10101010, B11101110,},
number_1[] = {B00000001, B11100100, B10101100, B10100100, B10100100, B10100100, B10100100, B11101110,},
number_2[] = {B00000001, B11101110, B10100010, B10100010, B10101110, B10101000, B10101000, B11101110,},
number_3[] = {B00000001, B11101110, B10100010, B10100010, B10101110, B10100010, B10100010, B11101110,},
number_4[] = {B00000001, B11101010, B10101010, B10101010, B10101110, B10100010, B10100010, B11100010,},
number_5[] = {B00000001, B11101110, B10101000, B10101000, B10101110, B10100010, B10100010, B11101110,},
number_6[] = {B00000001, B11101110, B10101000, B10101000, B10101110, B10101010, B10101010, B11101110,},
number_7[] = {B00000001, B11101110, B10100010, B10100010, B10100100, B10100100, B10100100, B11100100,},
number_8[] = {B00000001, B11101110, B10101010, B10101010, B10101110, B10101010, B10101010, B11101110,},
number_9[] = {B00000001, B11101110, B10101010, B10101010, B10101110, B10100010, B10100010, B11101110,},
number_10[] ={B00000001, B01001110, B11001010, B01001010, B01001010, B01001010, B01001010, B11101110,},
number_11[] ={B00000001, B01000100, B11001100, B01000100, B01000100, B01000100, B01000100, B11101110,},
number_12[] ={B00000001, B01001110, B11000010, B01000010, B01001110, B01001000, B01001000, B11101110,},
number_13[] ={B00000001, B01001110, B11000010, B01000010, B01001110, B01000010, B01000010, B11101110,},
number_14[] ={B00000001, B01001010, B11001010, B01001010, B01001110, B01000010, B01000010, B11100010,},
number_15[] ={B00000001, B01001110, B11001000, B01001000, B01001110, B01000010, B01000010, B11101110,},
number_16[] ={B00000001, B01001110, B11001000, B01001000, B01001110, B01001010, B01001010, B11101110,},
number_17[] ={B00000001, B01001110, B11000010, B01000010, B01000100, B01000100, B01000100, B11100100,},
number_18[] ={B00000001, B01001110, B11001010, B01001010, B01001110, B01001010, B01001010, B11101110,},
number_19[] ={B00000001, B01001110, B11001010, B01001010, B01001110, B01000010, B01000010, B11101110,},
number_20[] ={B00000001, B11101110, B00101010, B00101010, B11101010, B10001010, B10001010, B11101110,},
number_21[] ={B00000001, B11100100, B00101100, B00100100, B11100100, B10000100, B10000100, B11101110,},
number_22[] ={B00000001, B11101110, B00100010, B00100010, B11101110, B10001000, B10001000, B11101110,},
number_23[] ={B00000001, B11101110, B00100010, B00100010, B11101110, B10000010, B10000010, B11101110,},
number_24[] ={B00000001, B11101010, B00101010, B00101010, B11101110, B10000010, B10000010, B11100010,},
number_25[] ={B00000001, B11101110, B00101000, B00101000, B11101110, B10000010, B10000010, B11101110,},
number_26[] ={B00000001, B11101110, B00101000, B00101000, B11101110, B10001010, B10001010, B11101110,},
number_27[] ={B00000001, B11101110, B00100010, B00100010, B11100100, B10000100, B10000100, B11100100,},
number_28[] ={B00000001, B11101110, B00101010, B00101010, B11101110, B10001010, B10001010, B11101110,},
number_29[] ={B00000001, B11101110, B00101010, B00101010, B11101110, B10000010, B10000010, B11101110,},
number_30[] ={B00000001, B11101110, B00101010, B00101010, B11101010, B00101010, B00101010, B11101110,},
number_31[] ={B00000001, B11100100, B00101100, B00100100, B11100100, B00100100, B00100100, B11101110,},
number_32[] ={B00000001, B11101110, B00100010, B00100010, B11101110, B00101000, B00101000, B11101110,},
number_33[] ={B00000001, B11101110, B00100010, B00100010, B11101110, B00100010, B00100010, B11101110,},
number_34[] ={B00000001, B11101010, B00101010, B00101010, B11101110, B00100010, B00100010, B11100010,},
number_35[] ={B00000001, B11101110, B00101000, B00101000, B11101110, B00100010, B00100010, B11101110,},
number_36[] ={B00000001, B11101110, B00101000, B00101000, B11101110, B00101010, B00101010, B11101110,},
number_37[] ={B00000001, B11101110, B00100010, B00100010, B11100100, B00100100, B00100100, B11100100,},
number_38[] ={B00000001, B11101110, B00101010, B00101010, B11101110, B00101010, B00101010, B11101110,},
number_39[] ={B00000001, B11101110, B00101010, B00101010, B11101110, B00100010, B00100010, B11101110,},
number_40[] ={B00000001, B10101110, B10101010, B10101010, B11101010, B00101010, B00101010, B00101110,},
number_41[] ={B00000001, B10100100, B10101100, B10100100, B11100100, B00100100, B00100100, B00101110,},
number_42[] ={B00000001, B10101110, B10100010, B10100010, B11101110, B00101000, B00101000, B00101110,},
number_43[] ={B00000001, B10101110, B10100010, B10100010, B11101110, B00100010, B00100010, B00101110,},
number_44[] ={B00000001, B10101010, B10101010, B10101010, B11101110, B00100010, B00100010, B00100010,},
number_45[] ={B00000001, B10101110, B10101000, B10101000, B11101110, B00100010, B00100010, B00101110,},
number_46[] ={B00000001, B10101110, B10101000, B10101000, B11101110, B00101010, B00101010, B00101110,},
number_47[] ={B00000001, B10101110, B10100010, B10100010, B11100100, B00100100, B00100100, B00100100,},
number_48[] ={B00000001, B10101110, B10101010, B10101010, B11101110, B00101010, B00101010, B00101110,},
number_49[] ={B00000001, B10101110, B10101010, B10101010, B11101110, B00100010, B00100010, B00101110,},
number_50[] ={B00000001, B11101110, B10001010, B10001010, B11101010, B00101010, B00101010, B11101110,},
carita_0[] = {B11111111, B10011001, B10011001, B11111111, B10000001, B11000011, B11100111, B11111111,},
carita_1[] = {B11111111, B10011001, B10011001, B11111111, B10111101, B10111101, B11000011, B11111111,},
carita_2[] = {B11111111, B10011001, B10011001, B11111111, B10000001, B11000011, B11100111, B11111111,},
carita_3[] = {B11111111, B10011001, B10011001, B11111111, B10111101, B10111101, B11000011, B11111111,},
carita_4[] = {B11111111, B10011001, B10011001, B11111111, B11111111, B11111111, B10000001, B11111111,},
carita_5[] = {B11111111, B10011001, B10011001, B11111111, B11100111, B11011011, B11100111, B11111111,},
carita_6[] = {B11111111, B10111101, B00011000, B10111101, B11100111, B11011011, B11100111, B11111111,},
carita_7[] = {B11111111, B11111111, B00011000, B11111111, B11100111, B11011011, B11100111, B11111111,},
carita_8[] = {B11111111, B10111101, B00011000, B10111101, B11100111, B11011011, B11100111, B11111111,},
alarma_0[] = {B11111111, B10000001, B10000001, B10000001, B10000001, B10000001, B10000001, B11111111,},
alarma_1[] = {B11111111, B11000011, B10100101, B10011001, B10011001, B10100101, B11000011, B11111111,},
sigilo_0[] = {B10000001, B00000000, B00000000, B00000000, B00000000, B00000000, B00000000, B10000001,};
matrix.begin(0x70); // Matrix address
Serial.println("\n Starting");
//Blynk.begin(auth, ssid, pass); // normal Blynk Cloud server connection
//Blynk.config(auth, cloudserver); // for Blynk's cloud server if WiFi already connected
Blynk.begin(auth, ssid, pass, localserver); // for a local server requiring WiFi connection
int mytimeout = millis() / 1000;
while (Blynk.connect(1000) == false) { // wait here until connected to the server
if((millis() / 1000) > mytimeout + 8){ // try to connect to the server for less than 9 seconds
break; // continue with the sketch regardless of connection to the server
ArduinoOTA.setHostname(OTAhost); // for local OTA updates
ArduinoOTA.begin(); // for local OTA updates
timer.setInterval(15000, reconnectBlynk); // check every 15 seconds if we are connected to the server
rtc.begin(); //RTC CLOCK BEGIN
sensors.begin();// Sensor ds18b20
pinMode(sensorPin, INPUT);
timer.setInterval(5000L, leeTEMP); // check every 5 seconds temp sensor
timer.setInterval(250L, show_display); // update the display every 0.25 segundos
// Blynk.virtualWrite(V4, "clr"); //clean table at start. Not needed as I have a Button to clean the table.
BLYNK_WRITE(V3) {
switch (param.asInt())
case 1: // Item 1
Serial.println("Temperatura Seleccionada");
modotemperatura=1;
modocaritas=0;
modoalarma=0;
modoalarmasigilosa=0;
break;
case 2: // Item 2
Serial.println("Animación Seleccionada");
modotemperatura=0;
modocaritas=1;
modoalarma=0;
break;
case 3: // Item 3
Serial.println("Modo Alarma Intrusión");
modotemperatura=0;
modocaritas=0;
modoalarma=1;
break;
case 4: // Item 4
Serial.println("Modo Alarma Sigilosa");
modotemperatura=0;
modocaritas=0;
modoalarma=0;
modoalarmasigilosa=1;
break;
default:
Serial.println("Unknown item selected");
BLYNK_WRITE(V5)
int cleartable = param.asInt(); // Get value as integer
if (cleartable==HIGH){
BLYNK_WRITE(V6)
int value = param.asInt(); // Get value as integer
camuflada=value;
void reconnectBlynk() // reconnect to server if disconnected, timer checks every 60 seconds
if (!Blynk.connected()) {
if(Blynk.connect()) {
BLYNK_LOG("Reconnected");
BLYNK_LOG("Not reconnected");
void leeTEMP()
temp = sensors.getTempCByIndex(0);
if(temp <= -0){temp = 0;}
else if (temp > 50.9){temp = 50;}
else{temp = sensors.getTempCByIndex(0);}
delay(20);
Blynk.virtualWrite(V2, temp); //Temp at VPIN 2
if(modotemperatura==1) // temp selected at menu
if((temp >= 0) && (temp < 1)){ matrix.clear(); matrix.drawBitmap(0, 0, number_0, 8, 8, LED_ON); matrix.writeDisplay(); }
if((temp >= 1) && (temp < 2)){ matrix.clear(); matrix.drawBitmap(0, 0, number_1, 8, 8, LED_ON); matrix.writeDisplay(); }
if((temp >= 2) && (temp < 3)){ matrix.clear(); matrix.drawBitmap(0, 0, number_2, 8, 8, LED_ON); matrix.writeDisplay(); }
if((temp >= 3) && (temp < 4)){ matrix.clear(); matrix.drawBitmap(0, 0, number_3, 8, 8, LED_ON); matrix.writeDisplay(); }
if((temp >= 4) && (temp < 5)){ matrix.clear(); matrix.drawBitmap(0, 0, number_4, 8, 8, LED_ON); matrix.writeDisplay(); }
if((temp >= 5) && (temp < 6)){ matrix.clear(); matrix.drawBitmap(0, 0, number_5, 8, 8, LED_ON); matrix.writeDisplay(); }
if((temp >= 6) && (temp < 7)){ matrix.clear(); matrix.drawBitmap(0, 0, number_6, 8, 8, LED_ON); matrix.writeDisplay(); }
if((temp >= 7) && (temp < 8)){ matrix.clear(); matrix.drawBitmap(0, 0, number_7, 8, 8, LED_ON); matrix.writeDisplay(); }
if((temp >= 8) && (temp < 9)){ matrix.clear(); matrix.drawBitmap(0, 0, number_8, 8, 8, LED_ON); matrix.writeDisplay(); }
if((temp >= 9) && (temp < 10)){ matrix.clear(); matrix.drawBitmap(0, 0, number_9, 8, 8, LED_ON); matrix.writeDisplay(); }
if((temp >= 10) && (temp < 11)){ matrix.clear(); matrix.drawBitmap(0, 0, number_10, 8, 8, LED_ON); matrix.writeDisplay(); }
if((temp >= 11) && (temp < 12)){ matrix.clear(); matrix.drawBitmap(0, 0, number_11, 8, 8, LED_ON); matrix.writeDisplay(); }
if((temp >= 12) && (temp < 13)){ matrix.clear(); matrix.drawBitmap(0, 0, number_12, 8, 8, LED_ON); matrix.writeDisplay(); }
if((temp >= 13) && (temp < 14)){ matrix.clear(); matrix.drawBitmap(0, 0, number_13, 8, 8, LED_ON); matrix.writeDisplay(); }
if((temp >= 14) && (temp < 15)){ matrix.clear(); matrix.drawBitmap(0, 0, number_14, 8, 8, LED_ON); matrix.writeDisplay(); }
if((temp >= 15) && (temp < 16)){ matrix.clear(); matrix.drawBitmap(0, 0, number_15, 8, 8, LED_ON); matrix.writeDisplay(); }
if((temp >= 16) && (temp < 17)){ matrix.clear(); matrix.drawBitmap(0, 0, number_16, 8, 8, LED_ON); matrix.writeDisplay(); }
if((temp >= 17) && (temp < 18)){ matrix.clear(); matrix.drawBitmap(0, 0, number_17, 8, 8, LED_ON); matrix.writeDisplay(); }
if((temp >= 18) && (temp < 19)){ matrix.clear(); matrix.drawBitmap(0, 0, number_18, 8, 8, LED_ON); matrix.writeDisplay(); }
if((temp >= 19) && (temp < 20)){ matrix.clear(); matrix.drawBitmap(0, 0, number_19, 8, 8, LED_ON); matrix.writeDisplay(); }
if((temp >= 20) && (temp < 21)){ matrix.clear(); matrix.drawBitmap(0, 0, number_20, 8, 8, LED_ON); matrix.writeDisplay(); }
if((temp >= 21) && (temp < 22)){ matrix.clear(); matrix.drawBitmap(0, 0, number_21, 8, 8, LED_ON); matrix.writeDisplay(); }
if((temp >= 22) && (temp < 23)){ matrix.clear(); matrix.drawBitmap(0, 0, number_22, 8, 8, LED_ON); matrix.writeDisplay(); }
if((temp >= 23) && (temp < 24)){ matrix.clear(); matrix.drawBitmap(0, 0, number_23, 8, 8, LED_ON); matrix.writeDisplay(); }
if((temp >= 24) && (temp < 25)){ matrix.clear(); matrix.drawBitmap(0, 0, number_24, 8, 8, LED_ON); matrix.writeDisplay(); }
if((temp >= 25) && (temp < 26)){ matrix.clear(); matrix.drawBitmap(0, 0, number_25, 8, 8, LED_ON); matrix.writeDisplay(); }
if((temp >= 26) && (temp < 27)){ matrix.clear(); matrix.drawBitmap(0, 0, number_26, 8, 8, LED_ON); matrix.writeDisplay(); }
if((temp >= 27) && (temp < 28)){ matrix.clear(); matrix.drawBitmap(0, 0, number_27, 8, 8, LED_ON); matrix.writeDisplay(); }
if((temp >= 28) && (temp < 29)){ matrix.clear(); matrix.drawBitmap(0, 0, number_28, 8, 8, LED_ON); matrix.writeDisplay(); }
if((temp >= 29) && (temp < 30)){ matrix.clear(); matrix.drawBitmap(0, 0, number_29, 8, 8, LED_ON); matrix.writeDisplay(); }
if((temp >= 30) && (temp < 31)){ matrix.clear(); matrix.drawBitmap(0, 0, number_30, 8, 8, LED_ON); matrix.writeDisplay(); }
if((temp >= 31) && (temp < 32)){ matrix.clear(); matrix.drawBitmap(0, 0, number_31, 8, 8, LED_ON); matrix.writeDisplay(); }
if((temp >= 32) && (temp < 33)){ matrix.clear(); matrix.drawBitmap(0, 0, number_32, 8, 8, LED_ON); matrix.writeDisplay(); }
if((temp >= 33) && (temp < 34)){ matrix.clear(); matrix.drawBitmap(0, 0, number_33, 8, 8, LED_ON); matrix.writeDisplay(); }
if((temp >= 34) && (temp < 35)){ matrix.clear(); matrix.drawBitmap(0, 0, number_34, 8, 8, LED_ON); matrix.writeDisplay(); }
if((temp >= 35) && (temp < 36)){ matrix.clear(); matrix.drawBitmap(0, 0, number_35, 8, 8, LED_ON); matrix.writeDisplay(); }
if((temp >= 36) && (temp < 37)){ matrix.clear(); matrix.drawBitmap(0, 0, number_36, 8, 8, LED_ON); matrix.writeDisplay(); }
if((temp >= 37) && (temp < 38)){ matrix.clear(); matrix.drawBitmap(0, 0, number_37, 8, 8, LED_ON); matrix.writeDisplay(); }
if((temp >= 38) && (temp < 39)){ matrix.clear(); matrix.drawBitmap(0, 0, number_38, 8, 8, LED_ON); matrix.writeDisplay(); }
if((temp >= 39) && (temp < 40)){ matrix.clear(); matrix.drawBitmap(0, 0, number_39, 8, 8, LED_ON); matrix.writeDisplay(); }
if((temp >= 40) && (temp < 41)){ matrix.clear(); matrix.drawBitmap(0, 0, number_40, 8, 8, LED_ON); matrix.writeDisplay(); }
if((temp >= 41) && (temp < 42)){ matrix.clear(); matrix.drawBitmap(0, 0, number_41, 8, 8, LED_ON); matrix.writeDisplay(); }
if((temp >= 42) && (temp < 43)){ matrix.clear(); matrix.drawBitmap(0, 0, number_42, 8, 8, LED_ON); matrix.writeDisplay(); }
if((temp >= 43) && (temp < 44)){ matrix.clear(); matrix.drawBitmap(0, 0, number_43, 8, 8, LED_ON); matrix.writeDisplay(); }
if((temp >= 44) && (temp < 45)){ matrix.clear(); matrix.drawBitmap(0, 0, number_44, 8, 8, LED_ON); matrix.writeDisplay(); }
if((temp >= 45) && (temp < 46)){ matrix.clear(); matrix.drawBitmap(0, 0, number_45, 8, 8, LED_ON); matrix.writeDisplay(); }
if((temp >= 46) && (temp < 47)){ matrix.clear(); matrix.drawBitmap(0, 0, number_46, 8, 8, LED_ON); matrix.writeDisplay(); }
if((temp >= 47) && (temp < 48)){ matrix.clear(); matrix.drawBitmap(0, 0, number_47, 8, 8, LED_ON); matrix.writeDisplay(); }
if((temp >= 48) && (temp < 49)){ matrix.clear(); matrix.drawBitmap(0, 0, number_48, 8, 8, LED_ON); matrix.writeDisplay(); }
if((temp >= 49) && (temp < 50)){ matrix.clear(); matrix.drawBitmap(0, 0, number_49, 8, 8, LED_ON); matrix.writeDisplay(); }
if((temp >= 50) && (temp < 51)){ matrix.clear(); matrix.drawBitmap(0, 0, number_50, 8, 8, LED_ON); matrix.writeDisplay(); }
void show_display()
//*************** Check PIR state ***************************************
val = digitalRead(sensorPin); //lee pin sensor PIR
//*************** Clock update ******************************************
int gmthour = hour();
if (gmthour == 24){gmthour = 0;}
String displayhour = String(gmthour, DEC);
int hourdigits = displayhour.length();
if(hourdigits == 1){ displayhour = "0" + displayhour;}
String displayminute = String(minute(), DEC);
int minutedigits = displayminute.length();
if(minutedigits == 1){displayminute = "0" + displayminute;}
String displaysecond = String(second(), DEC);
int seconddigits = displaysecond.length();
if(seconddigits == 1){displaysecond = "0" + displaysecond;}
String displaycurrenttime = displayhour + ":" + displayminute;
Blynk.virtualWrite(V1, displaycurrenttime); //Display clock using V1
//*************** MODO ANIMACIÓN *******************************************
if(modocaritas==1) // facial expressions selected
if (sequence == 0){
matrix.clear();
matrix.drawBitmap(0, 0, carita_0, 8, 8, LED_ON);
if (sequence == 1){
matrix.clear();
matrix.drawBitmap(0, 0, carita_1, 8, 8, LED_ON);
if (sequence == 2){
matrix.clear();
matrix.drawBitmap(0, 0, carita_2, 8, 8, LED_ON);
if (sequence == 3){
matrix.clear();
matrix.drawBitmap(0, 0, carita_3, 8, 8, LED_ON);
if (sequence == 4){
matrix.clear();
matrix.drawBitmap(0, 0, carita_4, 8, 8, LED_ON);
if (sequence == 5){
matrix.clear();
matrix.drawBitmap(0, 0, carita_5, 8, 8, LED_ON);
if (sequence == 6){
matrix.clear();
matrix.drawBitmap(0, 0, carita_6, 8, 8, LED_ON);
if (sequence == 7){
matrix.clear();
matrix.drawBitmap(0, 0, carita_7, 8, 8, LED_ON);
if (sequence == 8){
matrix.clear();
matrix.drawBitmap(0, 0, carita_8, 8, 8, LED_ON);
if (sequence <= 8) {
sequence++;
else {
sequence = 0; // Reset the sequence to start again
//********************ALARMA INTRUSION*********************************************
if(modoalarma==1)
if (val == LOW) {
matrix.clear();
matrix.drawBitmap(0, 0, alarma_0, 8, 8, LED_ON);
Serial.println("TRANQUILO");
alarmaactiva=1;
Serial.println(alarmaactiva);
if((val == HIGH) && (alarmaactiva==1)) {
Blynk.virtualWrite(V4, "add", rowIndex, "Movimiento", displaycurrenttime);
Blynk.virtualWrite(V4, "pick", rowIndex);//highlighting latest added row in table
rowIndex++;
matrix.clear();
matrix.drawBitmap(0, 0, alarma_1, 8, 8, LED_ON);
Serial.println("INTRUSO DETECTADO");
alarmaactiva=0;
//********************ALARMA SIGILOSA ***********************************************
if(modoalarmasigilosa==1) // modo alarma supersigilosa selecionado
matrix.clear();
matrix.drawBitmap(0, 0, sigilo_0, 8, 8, LED_ON);
if (val == LOW) { alarmasilenciosa=1; }
if((val == HIGH) && (alarmasilenciosa==1)) {
rowIndex++;
alarmasilenciosa=0;
//**********************ALARMA OCULTA***************************************************
if((modoalarma==0) && (modoalarmasigilosa==0) && (camuflada==1))
if (val == LOW) { alarmacamuflada=1; }
if((val == HIGH) && (alarmacamuflada==1)) {
rowIndex++;
alarmacamuflada=0;
if (Blynk.connected()) { // to ensure that Blynk.run() function is only called if we are still connected to the server
ArduinoOTA.handle(); // for local OTA updates
Hope you like it!!
