BLYNK
3 sensor connect to 3 Motor
My Problem is With Blynk
First Mode auto it work normal
Then i change Mode Manual it work well
When i change back to Auto it not work
if i make for only one sensor it work well but when use 3 same sensor with 3 motor it not work well
  • Arduino NodeMCU
  • Soil Moisture Sensor(i use Digital)
  • Arduino 4 Channel Relay Module
  • DC Pump Motor
Sensor1 (16) control Motor1 (14)
Sensor2 (05) control Motor2 (12)
Sensor3 (04) control Motor3 (13)
cpp
char auth[] = " *********";
char ssid[] = "*****";
char pass[] = "****";
int sensorData;
int button2;
int button3;
int button4;
int selectmode;
int i;
int timer2;
int val;
int val2;
int val3;
WidgetLED led1(V1);
WidgetLED led2(V3);
WidgetLED led3(V5);
WidgetLED led4(V7);
WidgetLED led5(V8);
  pinMode(14,OUTPUT);
  pinMode(12,OUTPUT);
  pinMode(13,OUTPUT);
  pinMode(16,INPUT);
  pinMode(05,INPUT);
  pinMode(04,INPUT);
void Auto()
  if( i==0 && selectmode ==0)
  val = digitalRead(16);
  if(val == LOW )
  digitalWrite(14,HIGH);
  delay(20);
  digitalWrite(14,LOW);
  delay(20);
  val2 = digitalRead(16);
  if(val2 == LOW )
  digitalWrite(12,HIGH);
  delay(20);
  digitalWrite(12,LOW);
  delay(20);
  val3 = digitalRead(16);
  if(val3 == LOW )
  digitalWrite(13,HIGH);
  delay(20);
  digitalWrite(13,LOW);
  delay(20);
   Blynk.virtualWrite(V0,val);  // Sensor 1
    Blynk.virtualWrite(V2,val2); // Sensor 2
     Blynk.virtualWrite(V4,val3); // Sensor 33
timer2=timer.setTimeout(1000L,OFF);
void OFF()
  timer.deleteTimer(timer2);
void Manual()
    if(button2==1&&selectmode==1)
    led1.on();
  led1.off();
    if(button3==1&&selectmode==1)
    led2.on();
  led2.off();
    if(button4==1&&selectmode==1)
    led3.on();
  led3.off();
BLYNK_WRITE(V9) // Case 1 ONOFF
 button2 = param.asInt();
BLYNK_WRITE(V10) // Case 2 ONOFF
 button3 = param.asInt();
BLYNK_WRITE(V11) // Case 3 ONOFF
 button4 = param.asInt();
BLYNK_WRITE(V6) //Select Mode
 selectmode = param.asInt();
 if(selectmode ==1){
    led5.on();
    led4.off();
     timer.setInterval(1000L, Manual);
 else{
   led4.on();
   led5.off();
   timer.setInterval(15000, Auto);
BLYNK_CONNECTED(){
  Blynk.syncVirtual(V6); //Select Mode
  Blynk.syncVirtual(V9); // Case 1 ONOFF
  Blynk.syncVirtual(V10); //Case 2 ONOFF
  Blynk.syncVirtual(V11); //Case 3 ONOFF
Well the code is a little tricky to follow but some things I noticed that MAY be causing your issue
Here you use V6 to initiate the auto and manual timers, but they never get turned off. So essentially they could both be running together. So when you are in auto mode it gets to the if statements in the manual function and most/all of them will not be true therefore the else statement will be executed.
Also, it seems that your Auto function has an extra set of brackets, and
is not contained within the first if statement as the other two are. Not sure if this was done on purpose.
And I am not sure of the point of creating a timer just to delete it 1 second later.
thank you so much i newbie …
yes2 it always on then off like blink the output (motor)
how to change the V6
the Auto function my mistake it suppose
val = 16
val2 =05
val3= 04
i also not sure about timer delete 1 sec because i follow this automanualpump
This will depend on what you are trying to accomplish. As you do not want both timers enabled at the same time, you will need to disable one while enabling the other.
Which is what I would expect with both the auto mode and manual mode functioning at the same time.
Just blindly following someone elses code is probably not the best idea. You need to understand why they are doing what they are doing, and determine if this is what you are trying to achieve. You need to understand what is going on in the code first.
I suggest you take some time to learn about programming and its basic functions, like if/else functions. YouTube and Google are a good place to start. You will also want to read about SimpleTimer and how to properly utilize its functions. SimpleTimer can be a very powerful tool, and is almost a MUST for BLYNK. You will also need to study the BLYNK DOCS, and make sure you understand the BLYNK functions/commands, how they relate to certain widgets and how/when to properly use them.
After all of that take another look at your code and try to fix the things mentioned in my first post. If you are still struggling, then post your “fixed” code and we (the BLYNK Community) will see if we can provide any guidance/support and get you on the right track.
Thank you so much i had learn many thing it work well
but went i go to Auto Back it slow a bit to trigger …
I put disable timer at V6 (the timer i dedclare 2 that for Auto and manual)
Correct me if i wrong …
Thank you
cpp
// include your ESP library here
// and other blynk widget
// Auth Token in the Blynk App.
char auth[] = " b0b1b74bc5d8464cb5e3f3c4443a8ad9";
char ssid[] = "nikzhafran";
char pass[] = "678250nik";
int button2; //Manual Blynk Case 1 ONOFF
int button3; //Manual Blynk Case 2 ONOFF
int button4; //Manual Blynk Case 3 ONOFF
SimpleTimer timer;  // allocate a name (mytimer) to the timer
int selectmode; //Select Mode for Auto or Manual
int timer2; //Manual Blynk
int timer3; //Auto Blynk
int val;  // Sensor 1
int val2; // Sensor 2
int val3; // Sensor 3
//Configuration of the widges used at the Blynk panel in the mobile
WidgetLED led1(V1); //virtual led Blynk for Motor 1
WidgetLED led2(V3); //virtual led Blynk for Motor 2
WidgetLED led3(V5); //virtual led Blynk for Motor 3
WidgetLED led4(V7); //virtual led Blynk for Auto Mode
WidgetLED led5(V8); //virtual led Blynk for Manual Mode
  Serial.begin(115200);     // Set ESP8266 baud rate
  Blynk.begin(auth, ssid, pass); // Here your Arduino connects to the Blynk Cloud.
  //Motor
  pinMode(14,OUTPUT);
  pinMode(12,OUTPUT);
  pinMode(13,OUTPUT);
  //Sensor
  pinMode(16,INPUT);
  pinMode(05,INPUT);
  pinMode(04,INPUT);
void Auto()
  if(selectmode ==0)
  if(val == HIGH ) //if sensor 1 high
    led1.on(); // light 1 blynk on
    led1.off(); // light 1 blynk off
  val2 = digitalRead(05);
  if(val2 == HIGH ) //if sensor 2 high
  digitalWrite(12,LOW);//Motor 1 On
    led2.on(); // light 2 blynk on
  digitalWrite(12,HIGH); //Motor 1 Off
    led2.off(); // light 2 blynk off
  val3 = digitalRead(04);
  if(val3 == HIGH ) //if sensor 3 high
  digitalWrite(13,LOW);  //Motor 2 On
    led3.on();// light 3 blynk on
  digitalWrite(13,HIGH); //Motor 2 Off
    led3.off(); // light 3 blynk off
  Blynk.virtualWrite(V0,val);  // This code will update the virtual port 0 (Sensor 1)
  Blynk.virtualWrite(V2,val2); // This code will update the virtual port 2 (Sensor 2)
  Blynk.virtualWrite(V4,val3); // This code will update the virtual port 4 (Sensor 3)
void Manual()
    digitalWrite(14,LOW);//Motor 1 On
  digitalWrite(14,HIGH);//Motor 1 Off
    digitalWrite(12,LOW); //Motor 2 On
  digitalWrite(12,HIGH);//Motor 2 Off
    digitalWrite(13,LOW);//Motor 3 On
    led3.on(); // light 3 blynk on
  digitalWrite(13,HIGH);//Motor 3 Off
  timer.run(); // call the simple timer routine
// When App button is pushed - switch the state for v9
 button2 = param.asInt(); // Get the state of the VButton for Case 1 ONOFF
// When App button is pushed - switch the state for v10
 button3 = param.asInt(); // Get the state of the VButton for Case 2 ONOFF
// When App button is pushed - switch the state for v11
 button4 = param.asInt(); // Get the state of the VButton for case 3 ONOFF
// Sets btnPin HIGH or LOW depending on state of Button Widget
 selectmode = param.asInt(); // Get the state of the VButton for selectmode
 if(selectmode ==1){
timer.disable(timer3); // Disables the timer3
    led5.on(); // light 5 blynk on
    led4.off(); // light 4 blynk off
timer2=timer.setInterval(1000L, Manual);   // Setup a function to be called every 1000 ms
timer.disable(timer2); //Disables the timer2
   led4.on(); // light 4 blynk on
   led5.off(); // light 5 blynk off
  timer3=timer.setInterval(15000, Auto); // Setup a function to be called every 1500 ms
BLYNK_CONNECTED(){
Taking a quick look at the code I only see one thing that may be an issue. In your AUTO() function it appears that you have a bracket out of place.
You Have:
void Auto()
  if(selectmode ==0)
And it should probably be:
void Auto()
  if(selectmode ==0)
As for the lag I suspect it is because you have the timer set for 15 seconds, not 1.5 seconds as you comment states. You have an extra 0.
i see there had extra bracket at led 2 off…
ok i will change it thank you so much :blush:
Ok i had done complete code it work very well and perfect
cpp
  //Motor
  pinMode(14,OUTPUT);
  pinMode(12,OUTPUT);
  pinMode(13,OUTPUT);
  //Sensor
  pinMode(16,INPUT);
  pinMode(05,INPUT);
  pinMode(04,INPUT);
void Auto()
  if(selectmode ==0)
void Manual()
 if(selectmode ==1){
  timer3=timer.setInterval(1500, Auto); // Setup a function to be called every 1500 ms
BLYNK_CONNECTED(){
