Hello everyone,
Using Blynk for a pretty long time, i found i’d like to see new button style & function.
Currently, even “SMALL button” is too big ), because it is 2x2 size.
How good it could be, if we could have a 2x1 “horizontal” push button, with own integrated LED, perhaps with RGB color change possibility
for example, i’d like to replace standard button like that
or like that:
I see following benefits:
- LED widget has only 5 symbols for description - it is not enough. 2x1 button can have longer description making control page more clear to understand
- BUTTON widget is too big. I dont feel comfortable to change between tabs often
- small 2x1 horisontal push button with color indicator can improve control page density and increase overall customer satisfaction )
Typical example might be process launch button. Button action: start process trigger, button indicator color - depending on results received (black=idle/chillout, yellow=starting, green=started good, red= start fail)
Thank you in advance
