Hi Guys,
I am keen to know what might be the best method to reduce 24VAC down to 5VDC?
I would like to power this https://www.dultmeier.com/pdfs/de476ps-24-diaphragm-valve-manual.pdf
and the nodemcu off the one 24V Power Supply, any ideas?
Hi Guys,
First you need to rectify the AC to DC then use a Buck Converter to bring it down to 5v… efficient and little to no heat as a byproduct. Probably want to make sure you have filtering to keep the ESP power clean.
Google around for more… here is an older document I just found
Looks like a good document, thanks
you could also look around for some ready-made solutions.
For example:
