I have two devices that send info to Blynk (BlynkEdgent). It is working really well except that I have one Data Stream with all of the virtual pins (A combination of both devices)
What I am confused about is that I have to have one IOS App page that is accessed from each device.
So I have to choose the 1st device then look at the data then exit and select the other device and then view its data.
Can I not see all data in the one IOS View???
ie
Device 1 has V0 and V1
Device 2 has V3 and V4
Am I able to have a one IOS App that allows me to view both Device 1 and Device 2 in the same view or am I doing something wrong?
You can however send data from one device to another, using the HTTP(s) API, so that all data is available on one device, so can be used on one device tile.
I’m not familiar with that board I’m afraid, but if you can find an example of how to make an http client call with that board then it should give you some clues.
thank you, can you help me to modify the code you linked me? I need to send this: http://blynk.cloud/external/api/update?token=MyTokenCode&dataStreamId=3&value=0
I do not understand where insert this address. I tried but unsuccesfully. Thanks
Salvatore
If I were you I’d use the code structure from my ESP8266 and ESP32 examples, but use the HTTP library from the example that @John93 provided and tweak the HTTP syntax if necessary.
Yes… I tried to do that, but it is too difficult for me. I am searching the internet if someone did this but it seems that nobody in the world used an arduino mkr 1010 wifi to send web request to blynk server!
I need to be as small as I can, but I have ran out of pins. I have a gpio extender for the node mcu but I prefer to use mkr 1010 wifi because it have more native pins (enough for my project) without adding another hardware piece, because all the stuff must fit in a hand (like a small tv remote).
I agree with @John93, the ESP32 should be your first choice.
If you want small form factor then look at the Lolin ESP32 S2 Mini, although personally I find that the double header layout can be tricky to work with.
