Under the free plan, I can have up to 3 templates but only 2 devices. What is the usefulness/purpose of that 3rd template ?
Is it possible to create 2 templates that would both share the same physical device ?
What I need is (still under the free plan) to have 2 different mobile apps controlling the exact same device but displaying/controlling a different sub-set of the available widgets.
I think it might have been done because some Blynk IoT early adopters were given additional devices, so an additional template is useful for them.
No, you can have a “many to one” relationship with devices to templates - in other words a single template can have multiple devices linked to that template.
But, a device can only have one parent template.
You can’t do that with the free plan.
You might be able to do this with a Device Info Tab in the Plus/Pro plan, as a way to limit access to a UI that only you (as the administrator has access to).
The only other option is to use two free accounts and either a ‘sacrificial’ hardware device which simply forwards/receives data between one account and another using the REST API, or Node-Red to do the same thing.
Hi Pete, going back quite a few years when I started with the Legacy Blynk and needed help you have always provided awesome explanations and this time is no exception. I kind of expected that answer but hey, had to try…
Thanks a lot for your great support,
Jean-Pierre Roy
I admit to not having looked into automation much.
Due to the loss of a number of quite useful widgets ( like segmented switches and drop down menus ) from the legacy Blynk ( cause I can only afford the free plan ) my solution of adapting my old project to the new Blynk leads to using the maximum (30) datastreams and widgets.
I would like to create 2 different mobile apps that would control a single device. Each app would have about 20 widgets each (because there would be some overlap).
Can you provide a bit more insight as to how automation could help me in that specific scenario !
You can use automation to achieve that (read the documentation for more details), but the only disadvantage is the limitation (5 automations per organization).
