I need help with a project to control 2 stepper motors with a nodemcu, I already looked at all the topics already open and none helped me to solve this problem. When I test the code outside the blynk it works correctly, but as soon as I use the parameters for blynk no engine works.
I already checked the hardware and they are ok. I realize that when I press the V1 button, the engine energizes, but it does not take the steps I commanded. it feels like not giving time for everything stated in V1 .
1- NodeMCU
2- 2 DRV8825
3- 4 Push button (end of course)
4- power supply 3A
5- resistors pull down
6- 2 nema 17
//****************************BLYNK*************************
char auth[] = "****";
char ssid[] = "***";
char pass[] = "***";
//****************************MOTOR***************************
#include <AccelStepper.h>
#define DIR 14 //D5 //porta direção janela
#define STEP 12 //D6 //porta passos janela
#define DIR2 4 //D2 //porta direção cortina
#define STEP2 0 //D3 //porta passos cortina
const int dist = 1000; //Distancia que irá percorrer em passos janela
const int dist2 = 1000; //Distancia que irá percorrer em passos cortina
const int velo = 200; // velocidade da janela
const int velo2 = 200; //velocidade da cortina
const int acel = 100; //aceleração janela
const int acel2 = 100; //aceleração cortina
//******************JANELA******************
const int fimfechar = 2; //D4 fim de curso sensor, pino no +vcc para detectar fim de curso
const int fimabrir = 5; //D1 fim de curso quando abrir
const int liberar = 1; //TX desabilita driver
//******************CORTINA******************
const int fimfechar2 = 15; //D8 fim de curso sensor, pino no +vcc para detectar fim de curso
const int fimabrir2 = 13; //D7 fim de curso quando abrir
const int liberar2 = 16; //D0 desabilita driver
//***************************INTERRUPT*********************
void ICACHE_RAM_ATTR fimdecursoabrir(); //prioridade
void ICACHE_RAM_ATTR fimdecursofechar(); //prioridade
void ICACHE_RAM_ATTR fimdecursoabrir2(); //prioridade
void ICACHE_RAM_ATTR fimdecursofechar2(); //prioridade
//******************************LIBRARY********************
AccelStepper stepper1(AccelStepper::DRIVER, STEP, DIR);
AccelStepper stepper2(AccelStepper::DRIVER, STEP2, DIR2);
//*****************************FECHAR JANELA********************************
BLYNK_WRITE(V0){ //DIGITAL V0 BLYNK
int fechar = param.asInt(); // armazena em fechar, o valor do botao
int ifimfechar = digitalRead(fimfechar); //armazena o valor do fim de curso fechar em ifimfechar
if ((fechar == LOW) && (ifimfechar == LOW)) //condição para fechamento da janela
digitalWrite(liberar, LOW); //Habilita o drive para acionar o motor
stepper1.moveTo(dist); // Irá mover o valor declarado em "dist"
stepper1.run();
timer.setTimeout(2000L, Acaofechar); //aguarda 2 segundos e desativa o drive
void Acaofechar(){
digitalWrite(liberar, HIGH); //Desabilita o driver
Blynk.virtualWrite(V4,"fechou"); //Indica no celular atravez do display V3 que a janela fechou
//*****************************ABRIR JANELA********************************
BLYNK_WRITE(V1){ //DIGITAL V1 NO BLYNK
int abrir = param.asInt(); // Armazena em abrir, o valor do botão
int ifimabrir = digitalRead(fimabrir); //Armazena o valor do fim de curso abrir em ifimmabrir
if((abrir == LOW) && (ifimabrir == LOW)) //condição para abertura da janela
// o motor dará 100 passos em modo 1 para 360º sentido anti-horário *******ABRIR JANELA********
stepper1.moveTo(-dist); // Irá mover o valor declarado em "dist"
stepper1.run();
timer.setTimeout(2000L, Acaoabrir); //aguarda 2 segundos e desativa o drive
void Acaoabrir(){
Blynk.virtualWrite(V4,"ABriu"); //Indica no celular atravez do display V3 que a janela abriu
void fimdecursofechar(){
static bool fimfechar = HIGH;
static unsigned long statecurse;
if ((millis() - statecurse)>100) {
digitalWrite (liberar , HIGH);
Blynk.virtualWrite(V4,"PAREDE fechou");
statecurse = millis();
void fimdecursoabrir(){
static bool fimabrir = HIGH;
Blynk.virtualWrite(V4,"PAREDE ABRIU");
//**********************************FECHAR CORTINA**********************************************************************************
BLYNK_WRITE(V2){ //DIGITAL V2 BLYNK
int fechar2 = param.asInt(); // armazena em fechar, o valor do botao
int ifimfechar2 = digitalRead(fimfechar2); //armazena o valor do fim de curso fechar em ifimfechar
if ((fechar2 == LOW) && (ifimfechar2 == LOW)) //condição para fechamento da janela
// o motor dará 100 passos em modo 1 para 360º sentido horário ********FECHAR JANELA*******
digitalWrite(liberar2, LOW); //Habilita o drive para acionar o motor
stepper2.moveTo(dist); // Irá mover o valor declarado em "dist"
stepper2.run();
timer.setTimeout(2000L, Acaofechar2); //aguarda 2 segundos e desativa o drive
void Acaofechar2(){
digitalWrite(liberar2, HIGH); //Desabilita o driver
Blynk.virtualWrite(V4,"fechou!!"); //Indica no celular atravez do display V3 que a janela fechou
//*****************************ABRIR CORTINA********************************
BLYNK_WRITE(V3){ //DIGITAL V3 NO BLYNK
int abrir2 = param.asInt(); // Armazena em abrir, o valor do botão
int ifimabrir2 = digitalRead(fimabrir2); //Armazena o valor do fim de curso abrir em ifimmabrir
if((abrir2 == LOW) && (ifimabrir2 == LOW)) //condição para abertura da janela
stepper2.moveTo(-dist); // Irá mover o valor declarado em "dist"
stepper2.run();
timer.setTimeout(2000L, Acaoabrir2); //aguarda 2 segundos e desativa o drive
void Acaoabrir2(){
Blynk.virtualWrite(V4,"ABriu!!"); //Indica no celular atravez do display V3 que a janela abriu
void fimdecursofechar2(){
static bool fimfechar2 = HIGH;
static unsigned long statecurse2;
if ((millis() - statecurse2)>100) {
digitalWrite (liberar2 , HIGH);
Blynk.virtualWrite(V4,"cortina fechou");
statecurse2 = millis();
void fimdecursoabrir2(){
static bool fimabrir2 = HIGH;
Blynk.virtualWrite(V4,"cortina abriu");
pinMode(fimfechar,INPUT);
pinMode(fimabrir,INPUT);
pinMode(liberar,OUTPUT);
digitalWrite(liberar,HIGH);
attachInterrupt(digitalPinToInterrupt(fimabrir), fimdecursoabrir, RISING);
attachInterrupt(digitalPinToInterrupt(fimfechar), fimdecursofechar, RISING);
stepper1.setMaxSpeed(velo);
stepper1.setAcceleration(acel);
//*************************************CORTINA*************************************************
pinMode(fimfechar2,INPUT);
pinMode(fimabrir2,INPUT);
pinMode(liberar2,OUTPUT);
digitalWrite(liberar2,HIGH);
attachInterrupt(digitalPinToInterrupt(fimabrir2), fimdecursoabrir2, RISING);
attachInterrupt(digitalPinToInterrupt(fimfechar2), fimdecursofechar2, RISING);
stepper2.setMaxSpeed(velo2);
stepper2.setAcceleration(acel2);
stepper2.moveTo(dist2);
