[132356] Connecting to blynk-cloud.com:80
hello everyone,
Am using an Arduino Mega 2560 that is attached to an Ethernet Shield. I am trying to connect the Arduino to Blynk and am getting the error β€œ[132356] Connecting to blynk-cloud.com:80”. It keeps trying to connect to the cloud.
I have tried everything I could and did not succeed.
Please help.
This is my code:
#include <Ethernet.h>
char auth[] = β€œ72bd8d57269e4a7889c5b08174aa8194”;
Blynk.begin(auth); // Here your Arduino connects to the Blynk Cloud.
Blynk.run(); // All the Blynk Magic happens here…
Aside from NOT properly formatting your code…
Blynk - FTFC
… You are also missing some essential code required for your Ethernet shield :wink: Google around and/or look at the sketch builder options.
https://examples.blynk.cc/?board=Arduino%20Uno&shield=Ethernet%20Shield%20W5100&example=GettingStarted%2FBlynkBlink
EDIT - Well, perhaps you are using an Ethernet adapter without the SD card attachment??
Either way… have you tried Googling for generic Ethernet scripts to test with first?
hello,
Am using an Ethernet adapter with an SD card attachment.
I have not tried any scripts yet.
I will give it a try.
Then you need the relevant commands (shown in the example) to disable the SD it as it can apparently interfere.
hey, i was got this problem. and i solved it when i use other wifi.
