With many loads where a resistor is set to limit the current flow very good place to measure the current is the resistor itself! Naturally you need to know the value of limiting resistor (usually the printed value is accurate enough) and measure not the current but voltage drop. Then calculate the current. I=U/R. That said, you need a DC power not the PWM, off course.
