Ok, so if you’ve seen my other posts - I’m using the APP with Node-Red… to control several devices… great… but - there are 31 virtual pins - I’m using them merely to trigger events - not talk to real pins. Problem is - every thing I want to do I have to use a different “virtual pin” for… am I missing something - is there a way that a button can send back something other than 1 or 0 from the APP… then I could use the same “Pin” over and over…
So I have a button to turn light A on and off - another button to turn light B on and off… I need to use up 2 of the virtual pins. If I could send values other than 1 or 0 I could use the same “pin” for both… possible? Like a message “kitchen light on” “Bathroom light on” ???
