It won’t compile. Keep getting errors, so I clearly did it wrong.
Thought this was supposed to be easy Is there an example I could rip off?
Here are all the errors I get and below these are the sketch:
Thanks again for all your help!
Arduino: 1.6.13 (Mac OS X), Board: “Arduino/Genuino Uno”
In file included from /Users/Alex/Documents/Arduino/libraries/Blynk/src/Blynk/BlynkApi.h:17:0,
from /Users/Alex/Documents/Arduino/libraries/Blynk/src/BlynkApiArduino.h:14,
from /Users/Alex/Documents/Arduino/libraries/Blynk/src/Adapters/BlynkEthernet.h:18,
from /Users/Alex/Documents/Arduino/libraries/Blynk/src/BlynkSimpleEthernet.h:20,
from /Users/Alex/Downloads/Blynk_Release_v0.4.4 2/libraries/Blynk/examples/GettingStarted/BlynkBlink/BlynkBlink.ino:57:
/Users/Alex/Documents/Arduino/libraries/Blynk/src/Blynk/BlynkHandlers.h:155:5: error: expected initializer before ‘void’
void BlynkWidgetWrite ## pin (BlynkReq BLYNK_UNUSED &request, const BlynkParam BLYNK_UNUSED ¶m)
/Users/Alex/Documents/Arduino/libraries/Blynk/src/Blynk/BlynkHandlers.h:163:31: note: in expansion of macro ‘BLYNK_WRITE_2’
#define BLYNK_WRITE(pin) BLYNK_WRITE_2(pin)
/Users/Alex/Downloads/Blynk_Release_v0.4.4 2/libraries/Blynk/examples/GettingStarted/BlynkBlink/BlynkBlink.ino:68:1: note: in expansion of macro ‘BLYNK_WRITE’
BLYNK_WRITE(V0)
exit status 1
Error compiling for board Arduino/Genuino Uno.
“Show verbose output during compilation”
Blynk lets you create beautiful drag-and-drop visual interfaces
for your projects in 5 minutes. And it works with almost every
hardware out there.
Docs, Tutorials, everything: http://www.blynk.cc
Github: http://github.com/blynkkk
Blynk Community: http://community.blynk.cc
Follow Us: http://www.facebook.com/blynkapp
http://twitter.com/blynk_app
You’ll need, in general:
- Blynk App (download from AppStore or Google Play)
- Arduino UNO or similar microcontroller board
- Decide how to connect Arduino to the Internet
(USB, Ethernet, Wi-Fi, Bluetooth, …)
example.
Let’s turn ON your LED with Blynk!
In this example we’ll use Arduino UNO + Ethernet Shield
5 Steps guide:
(watch video tutorial here: )
- Connect LED to Pin 9
( http://arduino.cc/en/uploads/Tutorial/simplefade_bb.png )
In the Blynk App:
2. Create New Project
3. Email yourself Auth Token. You can do it later at any time
4. Add a Button Widget. Select Pin D9 in Widget’s Settings
5. Press Play icon. Enjoy Blynking!
You can find a QR code for easy setup of this project here:
https://github.com/blynkkk/blynk-library/tree/master/examples/GettingStarted/BlynkBlink
// Following includes are for Arduino Ethernet Shield (W5100)
// If you’re using another shield, see Boards_* examples
#include <Ethernet.h>
char auth[] = “YourAuthToken”; // Put your Auth Token here. (see Step 3 above)
Blynk.begin(auth); // Here your Arduino connects to the Blynk Cloud.
BLYNK_WRITE(V0)
int blabla = param.asInt();
if(blabla == 1)
digitalWrite(D3, HIGH);
digitalWrite(D3, LOW);
Blynk.run(); // All the Blynk Magic happens here…
// to avoid delay() function!
